Sound How to set a custom ringtone?
  1. G_abu_nime_Polash_JFru
    Cupcake May 27, 2017
    G_С_К_YpGR likes this.
  2. G_Amol_Kadam_aWQR
  3. G_С_К_YpGR
    Donut May 27, 2017
    G_С_К_YpGR , May 27, 2017 :
    OK, It helps to set ringtone for everyone from contact list. But I need set another melody only for one people. And it mp3 file on my phone
    Sang191 likes this.
  4. jmartelo
    Cupcake May 28, 2017
    jmartelo , May 28, 2017 :
    Thanks, now it worked.
  5. prasar
    Froyo Jul 9, 2017
    prasar , Jul 9, 2017 :
    I am trying to set a .aiff file as ring tone but can't :-(
    Are.aiff files supported to be set as ringtones?
  6. farooqsk1990
    Cupcake Jul 9, 2017
  7. kbocek
    Cupcake Jul 9, 2017
    kbocek , Jul 9, 2017 :
    But this displays *all* the music on your phone. I have a few custom ringtones. I just want to display the files in the Ringtones folder.
  8. sharkhark
    Gingerbread Sep 21, 2017
    sharkhark , Sep 21, 2017 :
    Thanks I couldn't figure this out. Worked instantly
    G_Mohit_Sharma_pvKy likes this.
  9. Jamie Garroch
    Cupcake Jun 12, 2018
    Jamie Garroch , Jun 12, 2018 :
    Go to settings - Sound - Phone ringtone - Choose sim - Local ring tone worked for me but the audio files I have just copied there with ES File Explorer didn't show up until I rebooted the phone.
  10. G_Dennis_Eck_dKaO
    Cupcake May 28, 2019
    G_Dennis_Eck_dKaO , May 28, 2019 :
    I do this on 3T: Place mp3 file in Notifications folder.
    Settings/Sound & vibration - Phone ringtone - Local ring tone (radio button) - Select your mp3.
    DONE!
  11. V1583423371139
    Cupcake Mar 5, 2020
    V1583423371139 , Mar 5, 2020 :
    To change your default ringtone your phones, you can head to the Settings >> Sound >> Ringtones and choose another song, audio, voice recording as the new ringtone. This is the way most people have their ringtones changed on mobile phone. You can find more details from this guide to set new ringtones on mobile phones. However this is actually the most difficult way as many steps are required. For example, if you want to set a song as new ringtones Samsung phone, you can actually launch the Music app on phones device and directly set it as the ringtone on mobile. Check out below steps if you want to do so.
    1. Start the Settings app.
    2. Tap “Sound and vibration.”
    3. Tap “Ringtone.”
  12. U1585044352246
    Cupcake May 27, 2020
  13. F1593397847942
    Cupcake Jun 29, 2020
    F1593397847942 , Jun 29, 2020 :
    First, download the ringtone file you like to your phone. Then go to the Ringtones and a Notifications folder and proceed to select the ringtone and settings. Note that the ringtone file must match the standard format of your phone.
  14. U1603460349783
    Cupcake Nov 3, 2020
