5
How to setup OnePlus TV with a external speaker?
  1. Harish_Rmcf
    Donut Sep 30, 2020
    Harish_Rmcf , Sep 30, 2020 :
    In digital legacy you'll hear true 5.1 surround sound if you play on amazon prime video or netflix. In Pcm you won't hear any proper surround effects. Oneplus should give more audio settings in tv. While on youtube my RT3 dont play all speaker at same time until i manually select PCM setting. :(
  2. Venky61
    OnePlus TV Expert Community Expert Sep 30, 2020
    Venky61 , Sep 30, 2020 :
    The audio settings available are sufficient enough if they work as intended. An auto switch between Dolby to Pcm mode is to be made possible in Auto and Passthrough which is not happening right now.
    Harish_Utekar likes this.
  3. Harish_Rmcf
    Donut Sep 30, 2020
    Harish_Rmcf , via OnePlus 7 , Sep 30, 2020 :
    Yes Exactly venky bro. As per content or application this should change it self but not working now. I tried two different HT systems. 😅 For youtube, and non 5.1 supported app it should be working as pcm
  4. Venky61
    I know the pain ;)
  5. neeru2000
    Eclair Nov 2, 2020
    neeru2000 , Nov 2, 2020 :
    I am trying to connect Boat Avante 1190 sound bar using the ARC to OnePlus Q1 but no luck. It connects with Bluetooth but not with hdmi. I also chose hdmi arc as sound out in tv settings but still no luck. Please help. Do I need something in between like an amplifier ?
  6. Harish_Rmcf
    Donut Nov 6, 2020
    Harish_Rmcf , via OnePlus 7T , Nov 6, 2020 :
    Try changing the cable. For arc you need high quality hdmi cables.
  7. sbhmnaik
    Froyo Nov 8, 2020
    sbhmnaik , via OnePlus 5T , Nov 8, 2020 :
    Using a good HDMI helped me get audio output from my HT. Just confirm if your HT Supports ARC if connected to HDMI ARC the HDMI ARC +/- is displayed on tv when volume of tv is increased or decreased.
  8. neeru2000
    Eclair Nov 12, 2020
    neeru2000 , Nov 12, 2020 :
    Purchased a new hdmi arc cable, works sometimes and sometimes no sound, don’t know if something is wrong with tv or sound bar or cable. Too confused.
  9. neeru2000
    Eclair Nov 12, 2020
  10. Harish_Rmcf
    Donut Nov 12, 2020
    Harish_Rmcf , via OnePlus 7T , Nov 12, 2020 :
    Which soundbar you have? Cz my friend is using mi tv and using boat soundbar with arc
    He also faces same issue 1 or 2 times in days. 😅
  11. neeru2000
    Eclair Nov 13, 2020
    neeru2000 , Nov 13, 2020 :
    OnePlus Q1 is the tv and boat avante 1190 sound bar
  12. N1579678839279
    Cupcake Nov 24, 2020
    N1579678839279 , Nov 24, 2020 :
    My LG Soundbar is connected via HMDI AR. Tv is disconnecting with soundbar automatically and TV remote is working to increase/decrease of sound. Can any one help me in this. I tried with samsung HT i faced the same problem.
  13. Venky61
    OnePlus TV Expert Community Expert Dec 9, 2020
    Venky61 , Dec 9, 2020 :
    Should be mostly to do with the HDMI cable... Can you change it and check?
  14. neeru2000
    Eclair Jan 16, 2021
    neeru2000 , Jan 16, 2021 :
    OnePlus Q1 is the tv and boat avante 1190 sound bar.
    Both have been checked by their respective service centre guys and both are in good shape. However oneplus guy reverted to old update of tv and it worked for some time. But then after few minutes TV stopped again producing sound via HDMI ARC to Boat sound bar. I have checked with 4 different good quality HDMI cables as per suggestions in the forum but nothing helped. This is really frustrating when you have spent 70K and nothing works as expected. Seems like the TV software is no good and need to be updated by Oneplus team. How do they roll out even without checking all the functions and leave it to consumers only. Bluetooth is also terrible and there's breaking sound all the time even when the sound-bar is just below the TV.
  15. Rick Y.
    OnePlus TV Software Engineer Staff Member Jan 27, 2021
    Rick Y. , Jan 27, 2021 :
    Can it work normally when the sound output is set to ARC (PCM) output?
  16. #36
