How to slow notification drawer slider to double tap lock
  1. Ashkeroth Eclair Aug 10, 2018
    Ashkeroth, Aug 10, 2018 :
    Hi Oneplus community,
    I own my OnePlus One, still in Cyanogen 11.0-XNPH05Q
    I noticed that recently when I tried to double tap the top of my screen to lock; the hexagon slider pops up faster - and when you slide, all the notifications shows up (if any).
    Is there a way to slow down the animation so that it can detect my double tap fast enough to lock my screen?
    I tried all the 3 window animation scale/transition animation scale/animator duration scale in the Developer Options in Settings. Did not work.
    Anyone knows a fix?
  2. Sridhar Ananthanarayanan Lollipop Aug 10, 2018
  3. Ashkeroth Eclair Aug 11, 2018
    Ashkeroth, Aug 11, 2018 :
    Thank Sri for replying. The alternative is to upgrade to Cyanogen 12.0-YNG1TAS2I3 but that removed the swipe lock screen rapid access to different apps.
  4. Ashkeroth Eclair Aug 11, 2018
    It appears setting the window animation scale/transition animation scale/animator duration scale all to x1 and leaving it overnight did the trick...
    EDIT:
    Hi all,
    After playing around; it appears that you can simply set Animator duration scale to 1.0x. It will allow you to double tap sleep without the hexagon slide bar popping up fast enough to swipe/peek notifications.
