How to switch between launchers on 3T?
  1. Nilanjan_Dubey
    Eclair Dec 22, 2016
    Nilanjan_Dubey , Dec 22, 2016 :
    Hi, I have installed google now launcher in my 3T. But how do I switch between Google now launcher and oneplus launcher because the "Home" option is not showing in settings?? How to switch between launchers? I am on oxygen os 3.5.4
    kobleznbitz likes this.
  2. philippone
    Donut Dec 22, 2016
    philippone , Dec 22, 2016 :
    Go to Settings -> Apps -> click on the gear-wheel in the upper right corner -> Standard-Apps -> select your preference for Desktop
    handheld_addict and kobleznbitz like this.
  3. 1+attrito
    Donut Dec 22, 2016
    1+attrito , Dec 22, 2016 :
    1. Go to Settings
    2. click on the search icon in the upper right corner
    3. search for "home"
    4. surprise surprise... the "home page" setting
    menù will appear in the search results.
  4. Nilanjan_Dubey
    Eclair Dec 23, 2016
    Nilanjan_Dubey , Dec 23, 2016 :
    yes this works. But in all phones there is a home option to switch between launchers. don't understand why its not present in 3T. may be a bug!
  5. Nilanjan_Dubey
    Eclair Dec 23, 2016
  6. Nilanjan_Dubey
    Eclair Dec 23, 2016
  7. ronin-panter
    Cupcake Dec 23, 2016
    ronin-panter , Dec 23, 2016 :
    Hi, i have the OnePlus Launcher and Google Launcher 3 installed. But in the Screen where you can select the launcher only the OnePlus launcher ist available. screen.png . Iam on Oxygen 3.5.4.
  8. iajay
    Eclair Dec 23, 2016
    iajay , Dec 23, 2016 :
    Same problem.. I cannot see the Home option.. even after searching..Iam on Oxygen 3.5.4
  9. iajay
    Eclair Dec 23, 2016
    -- yeah this solved the issue
  10. ronin-panter
  11. iajay
    Eclair Dec 23, 2016
  12. playhardk
  13. Hariki
    Cupcake Feb 18, 2017
    Hariki , Feb 18, 2017 :
    Mine is Oneplus 3T and it has the following menu: Settings>Apps>Gear Icon>Configure Apps Tap on Home App and Select the launcher you want, if you have more than one launcher. Attaching screen shots:
