202
How-to: Tips and Tricks for Screen Unlock
  1. BadAdalberto Cupcake Dec 1, 2018
    BadAdalberto, Dec 1, 2018 :
    Yes, the secure-glass it's already pre apply "from the box" .
  2. B1542750030457 Cupcake Dec 1, 2018
  3. NishitRanjan Cupcake Dec 1, 2018
    NishitRanjan, Dec 1, 2018 :
  4. goyal18 Cupcake Dec 2, 2018
  5. StachurskiMarcin Eclair Dec 2, 2018
    StachurskiMarcin, Dec 2, 2018 :
    first 150 unlocks the phone has missed 3. I'm fine with that.
  6. P1543764605152 Cupcake Dec 2, 2018
    P1543764605152, Dec 2, 2018 :
    Don't do it. It sucks. If the pixel was still on sale I'd return this thing.
  7. T1541189735561 Donut Dec 3, 2018
    T1541189735561, Dec 3, 2018 :
    I have been seeing alot of complaints with the fingerprint sensor lately.
    However, I am not sure why am I not facing any issue.
    My sensor is in par with the one on OP6.
    Initially when I added my prints, It was most of the time incorrect or else used to take couple of seconds to unlock.
    Later on, I found what I was doing wrong. Once I fixed it, It's blazing fast. I face no issues at all.
    Pinttas likes this.
  8. Tiffany_Miles_Writer Cupcake Dec 3, 2018
    Speedlover777 likes this.
  9. Speedlover777 Honeycomb Dec 3, 2018
    Speedlover777, Dec 3, 2018 :
    Hello, OnePlus developers!
    I suggest to place in-display fingerprint scanner above the battery in OnePlus 7 model, instead of placing it below the battery as in 6T. So, eventually, we will have the scanner at more comfortable to touch place — closer to center of the screen. Because, in order to reach the scanner in 6T model you have to struggle holding the phone firmly not to drop it, and trying to reach the bottom of the display. As a result of placing the scanner above the battery, the touching finger will touch the scanner with less missing rate, because the finger will touch mostly in one position.
    Best regards,
    Speedlover777
    pbud423 and muharrem1961 like this.
  10. rishichadda Cupcake Dec 4, 2018
    rishichadda, Dec 4, 2018 :
    the double tap to wake up screen gestures does not work properly when the screen is locked.
    thanks
    mjghi likes this.
  11. P1509383210991 Donut Dec 4, 2018
    P1509383210991, Dec 4, 2018 :
    I am facing issues of lag in fingerprint scanner of my OP 6T. I have to place my finger several times to unlock the screen. Also it take too much time to scan the finger and unlock. Please help.
    Q1527351796924 likes this.
  12. GopalB. Nougat Dec 4, 2018
    P1509383210991 likes this.
  13. mjguti Cupcake Dec 4, 2018
    mjguti, Dec 4, 2018 :
    I've got a quick question, sorry if it has been already asked elsewhere. I have a few apps (banks, utilities) that use the fingerprint reader for identification. In all cases, without exception, the reader works faster and more consistently than when unlocking the screen. What's up with that? I would assume that the APIs in use are the same...
  14. P1509383210991 Donut Dec 5, 2018
  15. P1509383210991 Donut Dec 5, 2018
  16. SantoshKenjalkar Donut Dec 5, 2018
    SantoshKenjalkar, Dec 5, 2018 :
    If finger print scanner works less than 0.3 seconds then it might be possible that animation while scanning fingers would not be visible
  17. Enzotto78 Cupcake Dec 5, 2018
    Enzotto78, Dec 5, 2018 :
    Buonasera a tutti. Sono felicissimo per il mio 6t ma non riesco proprio a far funzionare il lettore di impronte. Praticamente non ha mai sbloccato, nemmeno una volta. C'è qualche problema?
  18. Enzotto78 Cupcake Dec 5, 2018
    Qualcuno ha qualche suggerimento
    Le ho provate tutte. Ho registrato le impronte al buio, ho provato a farlo due volte con la stessa impronta. La procedura di registrazione si conclude correttamente ma alla fine non si sblocca mai. Aiuto
  19. G_Preet_Kacholiya_fDTe Donut Dec 6, 2018
    G_Preet_Kacholiya_fDTe, Dec 6, 2018 :
    I think the inbuild applocker should also unclock by face unlock with fingerprint as everytime during a conversation you just simply locks your phone and you open it again the applocker sometimes lacks in detecting fingerprint so a face unlock can help it!
    bdw iam pretty happy with the way it is
  20. homerop Cupcake Dec 7, 2018
    homerop, Dec 7, 2018 :
    One of the most common mishaps for me is wrong dials to people if I lock phone without minimizing phone app. As soon fingerprint unlock happens it dials contact under finger. Can you provide a fix or workaround for that from happening?
