190
How-to: Tips and Tricks for Screen Unlock
  1. Goggeboy Honeycomb Dec 25, 2018
    Goggeboy, Dec 25, 2018 :
    Wrong thread, but easy way is, just long press the power button and there it comes
    R1545411568228 likes this.
  2. U1545757474148 Cupcake Dec 25, 2018
    U1545757474148, Dec 25, 2018 :
    why is it that while im using my keypad specially in whatsapp the finger scanner comes up and stays there while im texting so i have to lock the phone and unlock so it can go away? help please
  3. G_Rohit_Banerjee_iALp Cupcake Dec 25, 2018
    G_Rohit_Banerjee_iALp, Dec 25, 2018 :
    I followed each and every point..but the issues are
    1) if someone else is pressing finger for sometime it unlocks
    2) after locking the screen of someone other than me use fingerprint it unlocks
    please help.
  4. P1545837845353 Cupcake Dec 26, 2018
    P1545837845353, Dec 26, 2018 :
    hello, is this normal? my 6t on the lock screen when I pull down the notification bar the screen noticably shifts to a yellowish tinge then when I flick the notification bar up the screen goes back to its original color?
    thanks!
  5. P1545837845353 Cupcake Dec 27, 2018
    P1545837845353, Dec 27, 2018 :
    try download the app Files made by Google. after I installed it it suggested I deleted those because they were taking up space.
  6. wengkie nagamurka Froyo Dec 27, 2018
  7. praveen_Nell Donut Dec 27, 2018
    praveen_Nell, Dec 27, 2018 :
    does having the ambient display always on drain the battery more with the fingerprint icon compared to previous models with always on screens? if not is it possible to have at least the fingerprint icon always on unless in a pocket so there's no need to tap once to get it to light up which will make the process faster? there are some inconsistencies with unlocking sometimes it will take longer to unlock and it will keep scanning with the animation too. i think stability and speed could be improved possibly with a future update maybe.
  8. charliecopley Honeycomb Dec 28, 2018
  9. charliecopley Honeycomb Dec 28, 2018
    charliecopley, Dec 28, 2018 :
    I wish add option to change the fingerprint sensor color. green can get quite bright in low light settings. maybe orange or red so doesn't disturb eyes as much.
  10. Z1543637199365 Cupcake Dec 29, 2018
    Z1543637199365, Dec 29, 2018 :
    when I drag the screen up device automatically unlocks without entering the fingerprint/pin/pattern
    pbud423 likes this.
  11. muharrem1961 Honeycomb Dec 30, 2018
  12. aniketsharma9865 Cupcake Dec 31, 2018
    aniketsharma9865, Dec 31, 2018 :
    Hye, yesterday I changed from iphone x to 6t...phone is great...but I have few questions. I used various news app for current news update as a notification on my iphone, but I dont know why those same apps are not giving timely lock screen popup notification on 6t. Other question is for whatsapp and other messengers, on Iphone I used to have setting in which when locked the notification will only show the header, but just when you unlock those notification threads will enlarge and show you the sender and content too on lockscreen itself. But on 6t I have to pick up phone unlock it either open the app or use notification panel and there also replies are not swift. I am new to this version of android are there are so many options to unlock the 6t and get notifications, can anyone guide me with the settings options to get them working like what I want. Thanks
  13. Vandhanakumari Eclair Dec 31, 2018
  14. Runouri Cupcake Jan 7, 2019
    Runouri, Jan 7, 2019 :
    hello
    when I lock the screen and try unlock ... if I put 2 or 3 times bad the finger, the mobile unlock.
    I check the smartunlock was desactivated.
    Any person with the same issue?
    thanks
  15. pbud423 Donut Jan 7, 2019
    pbud423, Jan 7, 2019 :
    There is a flaw in the lock screen.... you can unlock anybody's screen by pressing the power button, which brings up the camera quick launch by swiping up on the screen away from the camera widget it bypasses the finger print scanner and unlocks the phone/screen....this should not be happening!!!!
  16. pbud423 Donut Jan 7, 2019
    same here!!...I don't think this should be happening! Am I right??!
  17. OnePlus_Kingpin Gingerbread Jan 7, 2019
    OnePlus_Kingpin, Jan 7, 2019 :
    I tried it now. It lets me take a picture but does NOT unlock the device.
  18. pbud423 Donut Jan 7, 2019
    I'm having the same issue!!!
  19. pbud423 Donut Jan 7, 2019
    try swiping up on the screen further away from the camera widget
  20. OnePlus_Kingpin Gingerbread Jan 7, 2019
    it asks for my unlock code
