216
How-to: Tips and Tricks for Screen Unlock
  1. K1555481700322
    Cupcake Apr 18, 2019
  2. pedrito22
  3. 1+6tuser
    Cupcake Apr 23, 2019
    1+6tuser , Apr 23, 2019 :
    yes you're. absolutely right about the smile you get when the question comes around [e]1f609[/e].
  4. Lannis
    Lannis , Apr 23, 2019 :
    TAP on screen dosen't always work. You have to use the powerkey to wake up the phone.
  5. O1556163162272
    Cupcake Apr 25, 2019
  6. pedrito22
    pedrito22 , Apr 25, 2019 :
    Same issue. haven't found an answer to it. in my opinion, once it is program to face unlock, it is the top option to unlock the phone. if you wait a bit, you'll see a message saying that it can't recognize the face and request to tap where the fingerprint scanner is to unlock with the fingerprint.
  7. vincent.liu
    Froyo Apr 26, 2019
  8. vasu94
    Cupcake May 6, 2019
    vasu94 , May 6, 2019 :
    I have one plus 6t
    oos 9.0.13
    finger print lock was not working
    95 % not recognize my finger print
    Anemicfrog likes this.
  9. drl431
    Marshmallow May 6, 2019
    drl431 , May 6, 2019 :
    Did you read at least the first few pages of this thread? I only ask because this post is the same as your previous post.
  10. Z1557330741258
    Cupcake May 8, 2019
  11. vasu94
    Cupcake May 8, 2019
    vasu94 , May 8, 2019 :
    how u resolve it
  12. dm00389731
    Honeycomb May 11, 2019
  13. Calcustom
  14. Blazko666
    Eclair May 14, 2019
    Blazko666 , May 14, 2019 :
    Good informative and detailed post regarding the functioning of the on screen finger tech for the OnePlus 6t. I would like to add that though many manufacturers don't give this option and it's appreciative of OnePlus that they do, however, the plastic screen gaurd that comes with the device is of inferior quality and very much prone to scratches. Since the official OnePlus tempered glass has been out of stock for a while, I bought the Spigen tempered glass from Amazon. It's a case friendly one and works fine with the on screen fingerprint tech. Much recommended.
  15. R1545411568228
    Cupcake May 19, 2019
    R1545411568228 , May 19, 2019 :
    another easy way three fingers down from top to down .
  16. dm00389731
    Honeycomb May 19, 2019
    dm00389731 , May 19, 2019 :
    how it works i tried but device is only vibrate and nothing happened
  17. D1558333715351
    Cupcake May 20, 2019
    D1558333715351 , May 20, 2019 :
    Very Slow compare with other phones . i have used Moto Z play earlier , it was very fast in detecting fingerprint . [e]1f622[/e]
  18. Kalpesh_Ambaliya_7878
  19. Christopher Doherty
    Gingerbread May 20, 2019
    Christopher Doherty , May 20, 2019 :
    mine doesn't work to good hopefully the 7 pro will be better but my 6t is slow and really only works with one thumb and it's still not reliable and when I try other fingers it's even worse. but that's the chance I took taking part in a newer tech. and I'm ok with that.
    bgood36 likes this.
  20. alberto ferrer
    Cupcake May 21, 2019
    alberto ferrer , May 21, 2019 :
    it seems sometimes the finger scanner stops until the face is identified, I supposed it should work independently
    bgood36 likes this.
