141
[How To] Update Latest OOS Stable/Beta with Stock Or Custom Recovery without Data Loss !!
  1. kilian102201
    Cupcake Dec 14, 2016
    kilian102201 , Dec 14, 2016 :
    Hey,
    I was hoping that this patch would fix my wifi problem.
    I've got a problem where my wifi keeps connecting and disconnecting constantly.
    Is there any way that i can fix this. I'm on the latest software right now.
    Thanks in advance
  2. aleb91
    Gingerbread Dec 14, 2016
    aleb91 , Dec 14, 2016 :
    What is the method to flash this for unlocked bootloader, twrp and rooted with phh superuser and magisk?
    eurovortex likes this.
  3. ibanez966
    Eclair Dec 15, 2016
  4. Funk Wizard
    Lollipop Moderator Dec 15, 2016
    Funk Wizard , Dec 15, 2016 :
    Thats not possible, try again full zip via stock or twrp should do the trick. Hope you don't have a bad download.
  5. Funk Wizard
    I don't see any wifi problems and no disconnection at my end, may be you can try a clean flash
    Should roughly take 5 min, I answered this on XDA as well, are you the same user.?
  6. Funk Wizard
    Same method as explained on OP
    Flash Full zip
    Flash phh super user and Magisk
    Reboot system
  7. juandelacruz
    Cupcake Dec 15, 2016
  8. F_Steven_Ryanski_YJCM
  9. aleb91
    Gingerbread Dec 15, 2016
    aleb91 , Dec 15, 2016 :
    I haven't rooted yet, I thought I'd reboot into system before rooting to make sure the update worked. Is it normal to take so far 5 mins to boot? Or am I stuck on bootloop?
  10. aleb91
    HELP! My phone says it is encrypted and cannot be read? Have I lost all my data???
  11. kryoflux
    Froyo Dec 15, 2016
    kryoflux , Dec 15, 2016 :
    Had the same... original recovery, but phone did not want to install the update. As soon as I try ADB, it instantly gives me a "failed". When installing from internal memory, it goes to about 15%, then fails or simply reboots after 10 minutes.
    I ended up installing it with TWRP, but that can't be the solution.
  12. totti1
    totti1 , Dec 15, 2016 :
    Another link for full rom please, to many downlaods from google, not avaible.
  13. aleb91
    I would like to add a tip, after doing a nandoid backup, copy it to your PC before following the next steps!!!!
  14. Funk Wizard
    Mega link is up on the OP
    totti1 likes this.
  15. Funk Wizard
    Optional but yes you can do so on your pc or otg
  16. j0shuap
    Cupcake Dec 16, 2016
    j0shuap , Dec 16, 2016 :
    Does OnePlus provide these OTA updates (I'm using the full version w/ TWRP) with official file checksums? How do I know what I'm downloading is authentic?
  17. Funk Wizard
    Lollipop Moderator Dec 18, 2016
    Funk Wizard , Dec 18, 2016 :
    The official download page is generally updated later so i do not see official links yet so you have to wait a bit, however all the links that i have posted as downloads are 100% authentic and captured from oneplus official servers.
    You can either wait for the OTA to hit you phone download and fail and then download the full OTA and flash of just download the full zip from the downloads provided and flash away.
    All this coming from o Oneplus Mod, you should not be too concerned off ;-)
  18. Funk Wizard
    #38
  19. aleb91
    Gingerbread Dec 18, 2016
    aleb91 , Dec 18, 2016 :
    What do you mean?
    #39
  20. Funk Wizard
    Lollipop Moderator Dec 19, 2016
    #40
