141
[How To] Update Latest OOS Stable/Beta with Stock Or Custom Recovery without Data Loss !!
  1. F_Martyn_Roberts_qkrV
    Eclair Dec 19, 2016
    #41
  2. Funk Wizard
    Lollipop Moderator Dec 19, 2016
    Funk Wizard , Dec 19, 2016 :
    Yes i am on 3.5.4 with TWRP 3.0.3.0 and Root access with Supersu 2.79
    #42
    F_Martyn_Roberts_qkrV likes this.
  3. rahulrs0029
    Gingerbread Dec 20, 2016
  4. F_Martyn_Roberts_qkrV
    Eclair Dec 20, 2016
    F_Martyn_Roberts_qkrV , Dec 20, 2016 :
    What I mean is can you install the update rather then the full zip?
    #44
  5. Praty_28
    Jelly Bean Dec 21, 2016
    Praty_28 , Dec 21, 2016 :
    @Funk Wizard im on the latest version of oos and have xposed installed... When i use data traffic monitor from gravitybox i can see the exact download and upload speed... But when i turn on hotspot on my 3T and connect my oneplus 2 and use data the speed is not indicated in the meter on my 3T even though im downloading an app on my op2 it just shows 0kbps or very low usage in bytes... It used to indicate very well on my op2 but not workin on op3 can u plz check for me? Thank you! This only happens on hotspot normal usage on my 3T is indicated correctly.
    #45
  6. Devilevil
    Cupcake Dec 21, 2016
    Devilevil , Dec 21, 2016 :
    Dear Team,
    I have bought one plus 3t and the battery of the phone is draining when the phone is in pocket andwhen I take out of my pocket then the phone is very hot as well.
    Kindly confirm the problem at the earliest as it is creating problem for taking phone when you are out.
    #46
  7. C3C0
    Froyo Dec 21, 2016
    C3C0 , Dec 21, 2016 :
    I debugged traffic monitor in GravityBox based on your report and came to a conclusion it's some kind of a bug in OOS. As soon as wifi tethering is enabled stats for mobile data interface are not updated properly for data that go via tethered interface.
    Also when you take a look at the numbers for Tethering&portable hotspot in Android Settings / Data Usage / Cellular Data Usage, numbers are far from reality. They are much higher than they should be.
    #47
    Funk Wizard and Praty_28 like this.
  8. G_Soumik_Das_WMcx
    #48
  9. RandomDude66613
    Gingerbread Dec 21, 2016
    RandomDude66613 , Dec 21, 2016 :
    Is that possible to flash OOS 3.5.4 on OnePlus 3 instead of 3.2.8 that every OnePlus 3 users have now? Or OOS 3.5.x was made only for OnePlus 3T?
    #49
  10. Praty_28
    Yaa even i noticed that it shows usage in gb which i dont think is correct... Hope oneplus notices this bug and fixes it in next update.
    #50
  11. Praty_28
    No such heating issue for me try a factory reset. If the issue persists contact support and get ur device replaced.
    #51
  12. Mugundhan Rp
    #52
  13. Mugundhan Rp
    #53
  14. Baxxcipo
    Eclair Dec 21, 2016
    Baxxcipo , Dec 21, 2016 :
    please help.. i flashed stock recovery and now i try to sideload orginal stock rom.. but it says installation failed.. :/
    #54
  15. Synaptx
    Cupcake Dec 22, 2016
    Synaptx , Dec 22, 2016 :
    I'm curious if the sideloading the 1GB file (the full rom), would be a method that can update from 3.5.3 to 3.5.4?
    #55
  16. G_Harry_7333_Yzgi
    #56
  17. FishyFing
    Eclair Dec 22, 2016
    FishyFing , Dec 22, 2016 :
    Asked this a couple of days ago, but didn't get any reply.
    I have the stock recovery and OOS 3.5.3 with a (re)locked bootloader, and my device is encrypted. Every time I try to flash both the OTA zip, and the full zip, it fails. I've tried using the built in system updater, local file in system, local file kn recovery and ADB for both zips. None of these have worked (ADB gave me xfer 1.00).
    Any help would be greatly appreciated.
    #57
  18. Funk Wizard
    Lollipop Moderator Dec 22, 2016
    Funk Wizard , Dec 22, 2016 :
    Activate the pocket mode in gestures.
    No not recommended unless you want to brick your device.
    3T has OOS recovery version 2.0 you guys don't need to sideload, simply install from internal via local update.
    If you flash OP3 software on 3T what do you expect. Please flash the correct version for 3T which is 3.5.4/3.5.3
    Factory reset and then flash
    #58
    Praty_28 likes this.
  19. FishyFing
    Eclair Dec 22, 2016
    Will try it when I get home.
    #59
  20. anirudhanirock
