141
[How To] Update Latest OOS Stable/Beta with Stock Or Custom Recovery without Data Loss !!
  1. G_Harry_7333_Yzgi
    Cupcake Dec 22, 2016
    G_Harry_7333_Yzgi , Dec 22, 2016 :
    sorry my device is op3
    #61
  2. bigds01
    Eclair Dec 23, 2016
    bigds01 , Dec 23, 2016 :
    Is there a way to a full install on a phone with H20? I can't figure it out
    #62
  3. Sgobetta
    Cupcake Dec 23, 2016
    #63
  4. andres lv
    Cupcake Dec 24, 2016
    andres lv , Dec 24, 2016 :
    hey what I need to do to put de OTA patch into the local upgrade carpet(SD card root directory)
    #64
  5. Nghia Nguyen
    Nghia Nguyen , Dec 24, 2016 :
    I am sorry for giving question here, just because this is most active thread in the forum I think.
    I am using OP3T with H2OS, can you guide me how to move to OOS in the clean way.
    Many thanks and sorry for my english.
    #65
  6. stavros9222
    Cupcake Dec 26, 2016
    stavros9222 , Dec 26, 2016 :
    Hey all,
    I am currently trying to install 3.5.4 version from settings>system updates. It is downloaded at 100% but it does not proceed and it allowes me only to click on cancel download. Any suggestions?
    #66
  7. Pratik_Kotian04
    Cupcake Dec 27, 2016
    Pratik_Kotian04 , Dec 27, 2016 :
    Hello guys . I have purchased Oneplus3T 4 days ago.Sometimes the phone restarts while playing songs and using whatsapp simultaneously.I have also faced some issue where the sound was not coming from the speakers ,it was only after I restarted the phone it was working fine.Can anybody help as why am getting these issues or it is a normal case?After this update I am getting the issue
    #67
  8. G_dean_jones_FcLE
    Donut Dec 27, 2016
    #68
  9. G_arrow_series_plKy
  10. G_Thim_Soon_Chan_eTxn
    Eclair Dec 27, 2016
    #70
  11. runboy93
    Jelly Bean Dec 27, 2016
    runboy93 , Dec 27, 2016 :
    After every OTA update, you should wipe cache via recovery mode and let cache refresh.
    #71
  12. sayeedm789
    Froyo Dec 27, 2016
    #72
  13. boscosoans
    Cupcake Dec 29, 2016
    boscosoans , Dec 29, 2016 :
    @Funk Wizard: So I have installed TWRP, rooted and installed stock OOS 3.5.4. My questions are;
    1. For future updates, will they install automatically via the System Updater or do I need to manually flash it via TWRP?
    2. If answer to above is NO, I would like to have updates install automatically and keep root as well. Do I need to lock bootloader for this or what is best?
    #73
  14. Praty_28
    Jelly Bean Dec 29, 2016
    Praty_28 , Dec 29, 2016 :
    You cant update via system updater as ur phone is rooted, u might get notified abt a new update but u will have to manually download and flash the full latest zip file from twrp Recovery.
    #74
  15. afxmac
    Cupcake Dec 31, 2016
    afxmac , Dec 31, 2016 :
    Hi,
    is there a way to use the system update downloaded file to flash via TWRP?
    I cannot find the file on the system.
    I used the update notification to download the Nougat update today, by I can't use the system update function on a rooted system.
    thx
    afx
    #75
  16. Ra3zor0
    Donut Jan 1, 2017
    Ra3zor0 , Jan 1, 2017 :
    This method should work for going from 3.5.4 to 4.0 right? I am rooted with twrp and unlocked bootloader running OOS 3.5.4
    Edit: It works. Nice and smooth and bluetooth and LTE data work
    #76
    eurovortex likes this.
  17. _Marth_
    Froyo Jan 2, 2017
    _Marth_ , Jan 2, 2017 :
    Hi all, just a quick question :)
    Do you believe this method (For Stock Non Rooted Users with Stock Recovery) will also work to install OxygenOS 3.5.4 from the 4.0 leaked? I installed the leaked version and I am struggling in the attempt of reverting back the 3.5.4.
    I was thinking to use the 3.5.4 to install the official OTA for OxygenOS 4.0. If there are better ways to install directly the official OxygenOS 4.0 it would be also better.
    Thanks all in advance for the precious help! [e]1f60a[/e]
    following my OxygenOS version:
    #77
  18. F_Martyn_Roberts_qkrV
    Eclair Jan 2, 2017
    F_Martyn_Roberts_qkrV , Jan 2, 2017 :
    Hi funk wizard, will you be doing another thread for 4.0? There's an app 1plus updater but it only gets the OTA update which fails when you try to install via TWRP...
    #78
  19. acoon
    Donut Jan 2, 2017
    #79
  20. Funk Wizard
    Lollipop Moderator Jan 7, 2017
    Funk Wizard , Jan 7, 2017 :
    Thread updated to OOS 4.0.1
    #80
