how to use multi window feature in 9.0.2
  1. akshaysai
    Eclair Nov 2, 2018
    akshaysai , Nov 2, 2018 :
    please let me know how to use the multi window function in 9.0.2
    earlier I used to go to recent apps and press and hold the particular app for the multi window option to appear.
    now it just doesn't appear. please guide
  2. Deactivated User
    Nov 2, 2018
    deangilvin likes this.
  3. Maverick2.0
    KitKat Nov 2, 2018
  4. Deactivated User
    Nov 2, 2018
  5. LorenStuck
    Honeycomb Nov 2, 2018
    LorenStuck , Nov 2, 2018 :
    Not all apps do split screen out of the box. You have to go to Developer Options, scroll to the bottom, and select Force activities to be resizable. Reboot the phone, and it should have the option for all when you click the three dot menu when looking at recent apps.
  6. Maverick2.0
    KitKat Nov 2, 2018
    Maverick2.0 , Nov 2, 2018 :
    I was referring to the OP. I understood that you were referring to 9.0.2 and had helped him out. :)
