39
[HOW TO] Use old OnePlus Gestures on OnePlus 5T running OxygenOS 10
  1. Pierre02
    Honeycomb May 18, 2020
    Pierre02 , May 18, 2020 :
    I found a pretty easy way to use old OnePlus Gestures on OnePlus 5T running OxygenOS 10
    No root required
    1. Download this Settings Editor app
    2. Open it
    3. Choose "System Table"
    4. Search for "op_gesture_button_side_enabled"
    5. Set its value to "0"
    Done! I tested it on a OnePlus 5 and it worked fine. To revert you'll have to set "1" to that property
  2. jabby10
    Donut May 18, 2020
    Pierre02 likes this.
  3. Austin72
    Gingerbread May 18, 2020
    Austin72 , May 18, 2020 :
    Thank you. Honestly was looking everywhere for something like this and I don't even need adb for this!
  4. AndroidappS
    Donut May 19, 2020
  5. HBP87
    Ice Cream Sandwich May 19, 2020
  6. Pierre02
    Honeycomb May 19, 2020
    Pierre02 , May 19, 2020 :
    You have to use this adb command: adb shell cmd overlay enable com.android.internal.systemui.navbar.gestural (change enable to disable) to revert.
    With this method you will not be able to disable the navigation bar
  7. HBP87
    HBP87 , May 19, 2020 :
    Thanks. It's working but I would rather use the hardware buttons as they are much faster and easier to use.
  8. tiag0s
    Cupcake May 19, 2020
    tiag0s , May 19, 2020 :
    No root required
    2. Open it
    source
    P1516645719315 and sandeep104701 like this.
  9. pablofg1978
    Nougat Head Moderator May 19, 2020
    pablofg1978 , May 19, 2020 :
    Hello there,
    Please use the search before creating a new thread.
    Thread merged
  10. bawng_upa
    Honeycomb May 20, 2020
  11. bawng_upa
  12. bawng_upa
  13. Edgar Palau
    Gingerbread May 26, 2020
  14. ankitg345
    Eclair May 26, 2020
    Edgar Palau likes this.
  15. GaToKnechto42
  16. praksvarma
    Eclair May 26, 2020
    benbis and AadeshChodankar like this.
  17. Wes.Gorgy
    Cupcake May 27, 2020
  18. Focaccia
    Eclair May 27, 2020
  19. shahbaj alam
    Honeycomb May 28, 2020
    shahbaj alam , via OnePlus 5T , May 28, 2020 :
    install settings editor app from play store..
    https://play.google.com/store/apps/details?id=by4a.setedit22
    then search for "op_gesture_button_side_enabled"...
    edit the value and change it to 0(zero)...
    if this is not available,then manually add it..
    at top of the screen,you will have the option to add new row, click there, add op_gesture_button_side_enabled, then save it... after that set the value for that row to 0 (zero)...
    enjoy old OnePlus gestures...
  20. Waveform Modifier
    Marshmallow May 28, 2020
    Waveform Modifier , May 28, 2020 :
    It's already been shared. Please use search.
