39
[HOW TO] Use old OnePlus Gestures on OnePlus 5T running OxygenOS 10
  1. shahbaj alam
    Honeycomb May 28, 2020
    shahbaj alam , via OnePlus 5T , May 28, 2020 :
    i know, but in some cases, that row is not available.... so in that case you have to add row manually, that's the extra thing i told....
  2. Waveform Modifier
    Marshmallow May 28, 2020
  3. V1579901148244
    Cupcake May 28, 2020
  4. George Kritos
    George Kritos , May 28, 2020 :
    If I restart my phone i get back to previous gestures. The gesture value goes back to "1" . Is there a way to prevent that from happening or should we repeat the steps every time we restart the phone?
  5. Funk Wizard
    Lollipop Moderator May 28, 2020
    Funk Wizard , May 28, 2020 :
    I am going to merge this on the existing running thread
    Waveform Modifier likes this.
  6. Omar5T
    Honeycomb May 29, 2020
    Omar5T , via OnePlus 5T , May 29, 2020 :
    George Kritos
    If I restart my phone i get back to previous gestures. The gesture value goes back to "1" . Is there a way to prevent that from happening or should we repeat the steps every time we restart the phone?​
    did u resolve this issue friend?
    or we r all stuck with it?
  7. George Kritos
    Cupcake May 29, 2020
    George Kritos , May 29, 2020 :
    no, unfortunately I haven't found any solution to this issue! are you having the same issue?
  8. G_Sheep_Wizard_agMW
    Cupcake May 30, 2020
  9. trance_way
    Cupcake May 31, 2020
  10. Omar5T
    Honeycomb May 31, 2020
    Omar5T , via OnePlus 5T , May 31, 2020 :
    i have not updated my OS.... there's seems to be quite much issues with the current 10.0....so thinking to wait for the next one
  11. George Kritos
    George Kritos , May 31, 2020 :
    everything runs smoothly on my 5t. No issues at all. Just this thing with the gestures which is not a big thing in my opinion.
    Omar5T likes this.
  12. Omar5T
    really? what about battery, signal strength, camera, call record, ringtone, gap in gboard etc? (plz read tge comment in page 129-130 on the android 10 update page by Abdul) most of the comm members are kind of bashing....i first had bad experience with 9.0.10...
  13. George Kritos
    no issues with ringtone, battery life or signal strength, camera looks and feels exactly the same (maybe I am just lucky, I don't know). I have never used call record so I haven't tried it now either. Gap in Gboard is not an issue for me, it doesn't bother me aesthetically.
    Omar5T likes this.
  14. benbis
    Cupcake Jun 16, 2020
  15. Syamkumartg
    Cupcake Jun 17, 2020
  16. Waveform Modifier
    Marshmallow Jun 17, 2020
  17. P1516645719315
    Eclair Jun 17, 2020
    P1516645719315 , via OnePlus 5T , Jun 17, 2020 :
    as i checking ur point, i did the same as u did but still the value is zero.. working perfectly [e]270c[/e]🏻
  18. Syamkumartg
    #38
  19. youbi
    Marshmallow Assistant Head Moderator Jun 17, 2020
    youbi , Jun 17, 2020 :
    Hi,
    I just wanted to let you know that I merged your thread with this existing one. The truth is that this community its a big one and with lots of users discussing different matters, so usually the thing one might be thinking about to open a new thread probably already exists around here. :p So using the search first is always the best thing to do, and will help keeping the forum better organized. So please next time search about it before creating a new thread.
    Hope you understand.
    As for the gestures, I have to be honest. After the initial impact of the change from bottom gestures to side gestures I haven't really miss those and the side gestures work quite well. :) And really love the fast way to exchange between apps.
    #39
  20. Syamkumartg
    #40
