How to use USB Joystick with OnePlus 2?
  1. hushensavani
    Ice Cream Sandwich Sep 22, 2015
    hushensavani , Sep 22, 2015 :
    So I've got these 3 things,
    1. USB Joystick
    2. OTG Cable
    3. USB Type-C to MicroUSB Adapter
    I tried to connect these stuff together
    Then enabled OTG Option from Storage Settings and injected the adapter to my OnePlus 2. But the USB Joystick Hardware is not getting detected. Do I need to install any drivers? Or the USB Joystick is not getting enough power to boot-up? Please share some pointers. Thanks.
  2. Tokolozi
    The Lab Reviewer - OPPO Find N Sep 22, 2015
    Tokolozi , Sep 22, 2015 :
    Could be a driver issue, but till this point I've only used BT controllers.
    gmo8492 likes this.
  3. add1ct3dd
    Gingerbread Sep 22, 2015
  4. aaron.hossain75
    Lollipop Sep 22, 2015
  5. hushensavani
    Ice Cream Sandwich Sep 23, 2015
    hushensavani , Sep 23, 2015 :
    You need to enable OTG in Storage Settings if you want to mount a flash drive.
  6. hushensavani
    Nope.. This should work.. There must be something under the hood we're missing.
    aaron.hossain75 likes this.
  7. add1ct3dd
    Gingerbread Sep 24, 2015
    add1ct3dd , Sep 24, 2015 :
    It is enabled - still nothing.
  8. locatekrish
    Froyo Sep 24, 2015
    locatekrish , Sep 24, 2015 :
    Try using it with USB C OTG cable... Ppl are facing problems in the way you are doing !!!
  9. Papao
    KitKat Sep 24, 2015
    Papao , Sep 24, 2015 :
    All you can use.
    Plug and Play.
    or
    Plug and Pray.
    or
    Plug and Problem.
  10. hushensavani
    Ice Cream Sandwich Sep 28, 2015
    hushensavani , Sep 28, 2015 :
    LOL :D
  11. Devestator99
    Honeycomb Sep 28, 2015
    Devestator99 , Sep 28, 2015 :
    I tried it with one from eBay... No luck
  12. hushensavani
    I am using Micro-USB OTG Cable with Type-C Adapter for data transfer from my flash drive. It works fine with that. There's no USB C OTG cable is required for that.
