5
How To Verify Bullets Wireless Z Original or Fake via OnePlus 7T Glacier Blue
  1. Blazing[Shams] , via OnePlus 7T Glacier Blue , Jul 14, 2020 :
    Hi Good People,
    Good Day.
    I just got my Bullets Wireless Z today and sadly the Never Settle Logo is missing from inside the box. The logo must be in there. I believe unluckily i got a Fake Wireless Z.
    Anyway is there any way by which i can verify whether this one original OnePlus product or not? Just like for mobile device, originality can be checked through OnePlus website.
    Plz help me. I am very upset.
  2. S1594495625094
    Cupcake Jul 14, 2020
    S1594495625094 , Jul 14, 2020 :
    Same issue with mine also. Missing Never settle tagline in my packaging. Please somebody suggest to identify same
    Blazing[Shams] likes this.
  3. Blazing[Shams] , via OnePlus 7T Glacier Blue , Jul 15, 2020 :
    Sad to know that. But how is it performing? Does it make you feel fake product?
  4. Praty_28
    KitKat Jul 15, 2020
    Praty_28 , Jul 15, 2020 :
    It's not just you mate look here many people got a similar situation. It could be that they decided to change the packaging a bit and remove the logo or maybe they ran out of the never settle stickers? Who knows, as long as you ordered from official oneplus website everything should be fine.
  5. Blazing[Shams]
    Eclair Jul 15, 2020
    Blazing[Shams] , Jul 15, 2020 :
    @Praty_28 I did not buy it from the OnePlus store/web site. In my country, some businessman brings OnePlus products in bulk quantity from China and sells it here without any warranty. I bought it from them.
    Do you know how can I check if my OnePlus Bullets Wireless Z is original or not?
  6. Praty_28
    KitKat Jul 15, 2020
    Afaik there is now way to check whether your earphones are original or fake.
    But you can do one thing to verify whether its fake or not. Firstly charge your BWZ to 100% and then play a song on loop for ~20 hours and then check how much time it takes for the battery to die. Keep volume around 50-60% I had read in a review that at this volume the bullets last for ~20 hours before shutting down. Im 100% sure that no fake Bluetooth earbuds will last for 20 hours straight on a single charge.
  7. Blazing[Shams] , via OnePlus 7T Glacier Blue , Jul 15, 2020 :
    ok i will update you accordingly.
    Praty_28 likes this.
  8. U1592500665437
    Cupcake Jul 18, 2020
    U1592500665437 , Jul 18, 2020 :
    how many of you missing never settle tagline in ur bullets wireless z box I got little bit afraid if that tagline is not present means it's fake ah any one pls notify me
  9. BhushanGholap
    Cupcake Jul 29, 2020
    BhushanGholap , Jul 29, 2020 :
    Don't be upset the company changed the box .
    Parth Kamaliya likes this.
  10. BhushanGholap
  11. C1595996474184
  12. BhushanGholap
    Yes the changes are from company itself
  13. Praty_28
    KitKat Jul 29, 2020
    Praty_28 , Jul 29, 2020 :
    Yes true, but as he did not purchase from an authorized seller so he will have to double check to confirm its authenticity hence I asked him to do the extra testing.
  14. Blazing[Shams] , via OnePlus 7T Glacier Blue , Jul 29, 2020 :
    OnePlus should've declared an announcement regarding their decision in box design change. Really it creates confusion. Some of the boxes have the logo whereas some of them doesn’t.
    @Praty_28 let me inform you my Bullets Wireless Z performing well. From my use it lasts for 20hours+ @55% Volume. But guess what happens after few days use. A fake product might perform well when It's just new. So i guess with this test we can not confidently say It's original. There should be an official procedure to check the originality.
  15. #15
  16. BhushanGholap
    Yes that is also important to check product even if you buy from authorised seller
  17. BhushanGholap
    Today I talked with customer service. See this screenshot
  18. Praty_28
    KitKat Jul 29, 2020
    I feel your pair of bwz is genuine you need not worry. If it sounds decent and lasts 20 hours on first charge there is no chance that it is fake. If it were to be fake how would they profit from it if they fit in such high quality hardware? Batteries are expensive components especially one's that have such high efficiency. Most fake earbuds can be distinguished easily as either sound quality or battery life one of these 2 are always compromised.
    Blazing[Shams] and BhushanGholap like this.
  19. W1596005757317
    W1596005757317 , Jul 29, 2020 :
    I too bought the bullets wireless z and the "never settle" logo is missing in the box. Please reply if i have bought the original product or not.
  20. BhushanGholap
    Yes it is original product. I also bought 3 days before company changed the box design the logo was there only for starting sale
