4
HSA Battery for 1+1
  1. bahar_b Honeycomb Oct 21, 2016
    bahar_b, Oct 21, 2016 :
    Greetings to all.
    Does anyone here have been using this battery.
    What do you think or how their performance?
  2. manishsingh Ice Cream Sandwich Oct 21, 2016
  3. bahar_b Honeycomb Oct 22, 2016
    bahar_b, Oct 22, 2016 :
    I'll tell you when my order arrived
  4. Developed Donut Oct 23, 2016
  5. bengal70 Gingerbread Nov 6, 2016
    bengal70, Nov 6, 2016 :
    Have you received and/or installed? I saw the listing and just curious.
  6. bahar_b Honeycomb Nov 7, 2016
    bahar_b, Nov 7, 2016 :
    my 1st day used it look good.
    From 97% charged.
    Connecting ribbon about 2mm short and glued to battery wrappers.so it's stretch a bit
    agoinfly and Praty_28 like this.
  7. Misterick Froyo Nov 9, 2016
  8. arjun.rs Gingerbread Nov 9, 2016
    arjun.rs, Nov 9, 2016 :
    one plus one has 3000 mah battery. so there might be some issues if you use this battery.
  9. javiges Cupcake Nov 9, 2016
  10. Akarsh Adithya Cupcake Nov 10, 2016
  11. bahar_b Honeycomb Nov 10, 2016
    bahar_b, Nov 10, 2016 :
    I buy from ali express.
    Search in playstore.
    Just remember li-po,li-ion battery store so much power inside even can burn your device.
    All risk is yours.
    Alex Mirrors likes this.
  12. Bassick Honeycomb Nov 10, 2016
  13. RatChef Cupcake Dec 4, 2016
  14. 9652578124 Cupcake Dec 4, 2016
  15. SpainMinecrafter Cupcake Dec 8, 2016
  16. Desertbike Eclair Dec 9, 2016
    Desertbike, Dec 9, 2016 :
    After 2+ years my OPO battery is starting to show it's age. I've tried the "fixes" noted here and on the XDA developers pages, and while I'd love to buy a new OP3T its not in the cards right now. If this fix works I'd be willing to go for it to extend the life of what has been a pretty great phone. ********** sells it for $12.90 US, but does not include the tool kit that comes with the OEM battery kit for about $15. So, given that the difference in price is $2 for an extra 500mAh, does the battery work and last longer than the original one for those of you, who like me, have had the phone since brand new?
  17. Jac_Q Ice Cream Sandwich Dec 9, 2016
    Jac_Q, Dec 9, 2016 :
    No, you will not notice the extra 500-600mAh since the phone is configured to charge the battery to a certain voltage level (equivalent to the 3100mAh of the original battery).
    See the OP3(T) battery threads for more info.
    Surely it should feel like a new battery since it has not degradation.
  18. bahar_b Honeycomb Dec 9, 2016
    bahar_b, Dec 9, 2016 :
    HSA battery better than fake BLP571.
    How to spot a fake BLP571.?
    What i know QR code will not match.
    Alex Mirrors, CrAcKeZ and Praty_28 like this.
  19. Desertbike Eclair Dec 29, 2016
    Desertbike, Dec 29, 2016 :
    Thanks for the input. Now I have another problem. With Cyanogen closing its doors. I'll no longer get updates for the phone, so I might have to port over the Oxygen OS. Anyone have any problems with making the switch on a 1st generation OPO?
  20. api182 Ice Cream Sandwich Feb 24, 2017
    api182, Feb 24, 2017 :
    LineageOS...
    agoinfly likes this.
