I am having problems with my Bluetooth it pairs with the my oneplus buds Z but it drops connection via OnePlus 9 Pro
  1. aaduli71
    Cupcake Sep 19, 2021
    aaduli71 , via OnePlus 9 Pro , Sep 19, 2021 :
    I am having problems with my Bluetooth it pairs with the my oneplus buds Z but it drops connection, I tried it with other Bluetooth devices and I am having the same issue, I updated to the latest software for 1+ 9pro but it didn't fix the problem, I tried remove and pair again and tried multiple settings i was not successful.
  2. Dresa91
    User of the Year 2016; Most Active User 2020 Sep 19, 2021
    Dresa91 , Sep 19, 2021 :
    Can you please reset the bluetooth settings?
    Please also follow this guide https://oneplustips.com/fix-oneplus-7-and-7-pro-bluetooth/
    G_plusone, Caomhin and nerdkabir like this.
  3. nerdkabir
    Jelly Bean Sep 19, 2021
    nerdkabir , via OnePlus 7 Pro , Sep 19, 2021 :
    Have you tried connecting other Bluetooth devices/headphones with your phone? And are you facing the same drop issues with them as well? If not, try resetting your OnePlus Buds Z by long pressing the button for 15 seconds (you'll see a constant red light ). You'll need to pair it again with your phone and other devices it was paired with before. Do remove it from the paired list.
    Dresa91 likes this.
  4. aaduli71
    Cupcake Sep 21, 2021
    aaduli71 , via OnePlus 9 Pro , Sep 21, 2021 :
    I have tried all this nothing seem to help, the only way is to make one thing checked from the bluetooth settings it means either calls or audio enabled, but if I leave both enabled the only thing will work is calls
  5. Q1632248264664
    Q1632248264664 , Sep 21, 2021 :
    It's a defect with the phone. I had the same issue and had to replace the phone. One issue resolved, 20 others still present. Never settle.
  6. aaduli71
    Cupcake Sep 23, 2021
  7. Dresa91
    User of the Year 2016; Most Active User 2020 Sep 23, 2021
    Dresa91 , Sep 23, 2021 :
    What exactly did you try?
  8. aaduli71
    Cupcake Sep 24, 2021
    aaduli71 , via OnePlus 9 Pro , Sep 24, 2021 :
    I tried to disconnect the device and pair it again, i tried a different Bluetooth headset I got the same result, every time I have to do this to connect the buds, those are OnePlus buds Z, they will connect then I lose media sound, the only thing stays connected is calls, I tried to stop b'utooth search from location option, I tried to cleat cash I tried clear all b'utooth devices the restart the phone and pair the Bluetooth again it didn't work, I updated the software to the latest.
  9. Dresa91
    User of the Year 2016; Most Active User 2020 Sep 24, 2021
    Dresa91 , Sep 24, 2021 :
    Did you clear cache and storage of Bluetooth (in apps) or reset the Bluetooth settings via settings?
  10. aaduli71
    Cupcake Sep 27, 2021
  11. Dresa91
    User of the Year 2016; Most Active User 2020 Sep 27, 2021
    Dresa91 , Sep 27, 2021 :
    Did you also reset the buds?
  12. aaduli71
    Cupcake Oct 3, 2021
  13. stajni13
    Gingerbread Oct 3, 2021
  14. Reyman1908
    Donut Oct 6, 2021
    Reyman1908 , Oct 6, 2021 :
    Hi! I have the same problem to my OnePlus 7 Pro. Since I got the new update there are the same issues with my Bluetooth connection. It drops after a while and don't connect after resetting und reconnect. I need to try von delete it from my connection list and reconnect it. Sometimes it works sometimes not. I have to put back the headphone into the case. Also this sometimes works or not. I resetted Bluetooth like the instructions on the other thread. Doesn't work to me.
    I tried it also to connect to my car. Even there is the same problem.
    Eg. During watching a film a the sind drops completely and outputs the sound through the phones speaker, although it's still connected. Pushing the phone's speaker buttons to change the source to the headphone doesn't work. It's listed but I cannot click on it.
    How long does this take to solve.
  15. Reyman1908
    Donut Oct 6, 2021
    I solved it. Delete the Alibaba and Alixpress app. I read it in an another thread. And it works!
    Don't know why these apps...
    Dresa91 likes this.
