i am not able to get suggested articles in Chrome even after enabling suggested article in setting
  1. Anand Ravat
    Donut Jun 4, 2019
  2. the_o2
    OnePlus 9 Series Expert Community Expert Jun 6, 2019
    buntycubal likes this.
  3. Anand Ravat
    Donut Jun 6, 2019
    Anand Ravat , Jun 6, 2019 :
    I have done that
  4. the_o2
    the_o2 , Jun 6, 2019 :
    Did you had enabled/modified something from the Chrome://flags
  5. Anand Ravat
    Donut Jun 6, 2019
    yes
  6. the_o2
    I think something is related to that, same happened in my friend's Redmi phone too,
    Better to reset all the settings to default or clear the cache and storage of the app and then try.
  7. Anand Ravat
    Donut Jun 6, 2019
    ok i will try that also
  8. the_o2
    OnePlus 9 Series Expert Community Expert Jun 8, 2019
    the_o2 , Jun 8, 2019 :
    Update the chrome to version 75.0.xx, I think it solved that issues.
  9. Anand Ravat
    Donut Jun 8, 2019
    Anand Ravat , Jun 8, 2019 :
    i have updated one then also issue not solved . I think I have to take it to service centre
