I am unable cast screen from one plus 7pro to LG Smart TV
  1. K1579550114569
    Cupcake Jul 3, 2020
    K1579550114569 , Jul 3, 2020 :
    Hi
    when I try to screen cast from my one plus 7 pro it's not detecting the LG smart TV .. where as from other phones I am able to screen cast.
    I enabled wireless display in settings as well still it's not works .. can anyone help me on this please .
  2. pablofg1978
    Nougat Head Moderator Jul 3, 2020
    pablofg1978 , Jul 3, 2020 :
    Hello there,
    Is your TV and phone on the same wifi network?
  3. K1579550114569
    Cupcake Jul 3, 2020
    no I have used my phone hotspot though to connect to internet in TV
  4. pablofg1978
    Can you try using another wifi?
  5. K1579550114569
    Cupcake Jul 3, 2020
    sure will give that a try ... but is it necessary to be on same wifi ... because other phones worked without this
  6. pablofg1978
    Yes, it is necessary.
    It won't work without a stable connection between both devices
  7. K1579550114569
    Cupcake Jul 3, 2020
    I connected both the TV and phone to same wifi but still it's not working
  8. spot01
    Ice Cream Sandwich Jul 3, 2020
    spot01 , Jul 3, 2020 :
    Do you now see your TV in the cast option?
  9. K1579550114569
    Cupcake Jul 3, 2020
    no it doesn't show up anything it just searched for available devices and closes automatically ... in settings when I check also it shows no device found like that
  10. spot01
  11. K1579550114569
    Cupcake Jul 3, 2020
    I figured it out ... it's working now ... thanks for your insights.
  12. spot01
    Good to know, perhaps share your steps here to help others who may be struggling
  13. K1579550114569
    Cupcake Jul 3, 2020
    I kept the wifi on did not connect to any network Both in TV and in phone ... then when I turned on the screen cast it automatically detected the LG smart TV then was able connect
  14. J_Duece_81
    Gingerbread Jul 3, 2020
    J_Duece_81 , Jul 3, 2020 :
    Glad you got it to work, I used to cast to a Chromecast this way on my 5t. It worked perfectly the first time, but then I reset it and couldn't get it to reconnect as easily. Then I used up all of my hotspot data one month and couldn't even mirror my screen on the Chromecast. I haven't tried this with my 7 Pro, (I have home wifi now) but it's good to know it works on some devices at least.
