3
I am unable to make outgoing calls but incoming is ok..I think, my settings has changed, Help plz
  1. lokeshkashi
    Cupcake Dec 28, 2014
    lokeshkashi , Dec 28, 2014 :
  2. Chevanlol360
    Honeycomb Dec 28, 2014
  3. msri3here
    Ice Cream Sandwich Dec 28, 2014
    msri3here , Dec 28, 2014 :
    did you pay your phone bill? can you send sms?
    try to put in another working sim and check
    sh3llshock and france42 like this.
  4. lokeshkashi
    yes I can send SMS...and there is enough balance in my phone...ACtually, When I am trying to call, I am getting "Call Ended" immediately ...
  5. msri3here
    could be lot of factors
    1. you dont have proper signal in your area. try going to a location near some tower and check
    2. are you using a bumper case (aluminium)? if yes, remove it and try
    3. Could be a problem with your sim card. Try to use a different sim and check if you can make calls
    Sagar_pi and sh3llshock like this.
  6. sh3llshock
    KitKat Dec 28, 2014
    sh3llshock , Dec 28, 2014 :
    Give this guy a cookie.
    t4ww4b likes this.
  7. lokeshkashi
    No...I hv tried calling using another sim too but failed to make calls. and i m totally unaware of bumper case ( aluminium) can please tell me where to check it ?
  8. leemartin
    Lollipop Dec 28, 2014
  9. lokeshkashi
    sorry.. i dont use bumper case ( aluminium) . please solve the problem at the earliest
  10. lokeshkashi
    It shows "call ended"
  11. felipe_colombia
    Eclair Dec 28, 2014
  12. ndr696969
    KitKat Dec 28, 2014
  13. mwayner
    mwayner , Dec 28, 2014 :
    Immediately after dialing? No ring tone? No automated message?
  14. NickWilliams_44
    Eclair Dec 28, 2014
  15. mwayner
    Well, Privacy Guard can block the Dialer but it will prompt whether or not to allow the call. Maybe @lokeshkashi should reboot in Safe Mode and try calling.
  16. macem29
    Jelly Bean Dec 28, 2014
    macem29 , Dec 28, 2014 :
    solution for you has 2 steps:
    1) sell this phone
    2) buy one pre-configured for your provider
    this is not for you
  17. lokeshkashi
    Cupcake Dec 29, 2014
    lokeshkashi , Dec 29, 2014 :
    yup...immediately after dialing...what to do?? any solution
  18. mwayner
    Lollipop Dec 29, 2014
    mwayner , Dec 29, 2014 :
    Did you try it in safe mode?
  19. lokeshkashi
    Cupcake Dec 31, 2014
    lokeshkashi , Dec 31, 2014 :
    Safe mode?? How to start phone in safe mode
  20. mwayner
    Lollipop Dec 31, 2014
    mwayner , Dec 31, 2014 :
    Holds the power button until the menu appears. Touch and hold the 'reboot' option until prompted to reboot in safe mode.
