2
I bought one plus 8t recently. I have problem with its software.. System UI ISN'T RESPONDING.. SO I
  1. the_o2
    OnePlus 9 Series Expert Community Expert Jan 27, 2021
    the_o2 , Jan 27, 2021 :
    Clear the storage data of the launcher app and restart your phone once and see
  2. E1597669922813
    Froyo Jan 27, 2021
  3. Tilak G.
    Ice Cream Sandwich Jan 27, 2021
    Tilak G. , Jan 27, 2021 :
    Clear Cache and storage of the Launcher, Restart your Phone after that.
    If it doesn't help try a Reset,but Make sure to ""DO A BACKUP BEFORE YOU RESET"" said:
    It should do the work.
  4. E1597669922813
    Froyo Jan 27, 2021
    E1597669922813 , via OnePlus 8T , Jan 27, 2021 :
    Yes factory reset complete but no problem slove
  5. Dresa91
    User of the Year 2016; Most Active User 2020 Jan 27, 2021
  6. #26
  7. E1597669922813
    Froyo Jan 27, 2021
  8. E1597669922813
    Froyo Jan 27, 2021
  9. #29
  10. E1597669922813
    Froyo Jan 27, 2021
    I bought one plus 8t recently. I have problem with its software.. System UI ISN'T RESPONDING.. SO I REQUEST MY PROBLEM SHOULD BE SOLVE AS SOON AS POSSIBLE.
    Please problem slove
    I have 2 phone one plus 8T but same facing issue trouble shot complete clear cache launcher clear all but no problem slove factory reset also completed
    Please problem slove through OTA FILE
  11. E1597669922813
    Froyo Jan 27, 2021
  12. Dresa91
    Dresa91 , Jan 27, 2021 :
    Just to make sure:
    You cleared cache via recovery and you did a factory reset, right?
  13. puccellino
    Lollipop Jan 27, 2021
    puccellino , Jan 27, 2021 :
    Have you logged the issue with oneplus and spoken to their support team. What was their response? Did they give you a case number?
    There are quite a few people with this issue, you are the third I've spoken to. However, I have an 8T, and I do not have this problem at all. So it's not affecting all phones, which means
    1. It has something to do with the way you set your phone up, widgets apps etc
    Have you gone through the basics suggested on the internet when this error occurs. For example, tested for these issues
    https://www.guidingtech.com/fix-system-ui-has-stopped-issue-android/
    2. It could be a hardware issue, or perhaps a faulty component. Perhaps there was a batch of these components.
    I suggest you log the issue through the feedback section, and clearly explain the issue. , Stating the IMEI and batch number, if you have not done so already. Check with Starcommander if you got the phone from the same region etc.
    The more good and clear information you give the company, the easier it is for them to rectify the issue. If you want your issue fixed, you need to do a bit of work. Perhaps visit a service centre as well.
    Good luck in fixing your issue.
  14. #34
    E1597669922813 likes this.
  15. E1597669922813
    Froyo Jan 27, 2021
  16. E1597669922813
    Froyo Jan 27, 2021
    I'm already all trouble shot complete but this is problem after software update 11.0.6.8 problem me
  17. E1597669922813
    Froyo Jan 27, 2021
    #38
  18. E1597669922813
    Froyo Jan 27, 2021
    #39
  19. E1597669922813
    Froyo Jan 27, 2021
    How to downgrade one plus 8 T tell me
    #40
