I brick my OP5T
  1. Praty_28 Jelly Bean Apr 15, 2018
    Praty_28, Apr 15, 2018 :
    No you will not lose twrp after the wipe and yes you can flash magisk after you flash the full rom zip.
  2. AtZ_SpeKtruM Gingerbread Apr 15, 2018
    AtZ_SpeKtruM, Apr 15, 2018 :
    does the official OTA.zip from One Plus.com include gapps ? or i need to download and flash them also ?
  3. Nicky_Wallace Froyo Apr 15, 2018
  4. Nicky_Wallace Froyo Apr 15, 2018
    Nicky_Wallace, Apr 15, 2018 :
    If is dose u do not need to do anything apart from install it
    AtZ_SpeKtruM likes this.
  5. AtZ_SpeKtruM Gingerbread Apr 15, 2018
    i don't understand can you talk english please
  6. AtZ_SpeKtruM Gingerbread Apr 15, 2018
    Ok so i try to follow your steps by wiping evreything except internal storage and after that i flash the Official OTA but i get an error when i flash it "zip file is corrupt !"
  7. jrocc79 Froyo Apr 15, 2018
  8. Hydra Bob Starting Point Expert Apr 15, 2018
    Hydra Bob, Apr 15, 2018 :
    So download the zip again and check the md5 hash before you flash it.
    For the full 5.0.4 zip it should be 045109a30afefc478593419f87d8b938
    Praty_28 likes this.
  9. Nicky_Wallace Froyo Apr 15, 2018
  10. keeratsawhney Froyo Apr 15, 2018
    keeratsawhney, Apr 15, 2018 :
    Boot Into TWRP. Go To Wipe, Advance Wipe and Select Erase, Type Yes. and Now Connect Your USB Cable To The Pc, Copy The OTA File From OnePlus Website to the root of storage. Go to Install and Select Install ZIP.
    This will 100% Work
    Note: This Will Erase All Your Data.
  11. AtZ_SpeKtruM Gingerbread Apr 15, 2018
    i succesfuly flash ota and magisk but when i reboot my phone it doesn't work not even the bootanimation pop there is just the one plus logo and phone doesn't want to boot
  12. Hydra Bob Starting Point Expert Apr 15, 2018
    Factory reset and try again. Don't flash Magisk until after the phone boots successfully for the first time.
  13. AtZ_SpeKtruM Gingerbread Apr 15, 2018
    so i wipe again all except internal storage and i flash the ota i reboot my phone and now i have a bootloop and i lose the twrp
  14. keeratsawhney Froyo Apr 15, 2018
    It is very important for you to Erase All Data Under Wipe Section in TWRP ( Including Internal Storage) and Then flashing OTA.
  15. keeratsawhney Froyo Apr 15, 2018
    Dont Flash Magisk After Flashing OTA. It Will Take Some Time at The Boot Screen. Be Patient
  16. Nicky_Wallace Froyo Apr 15, 2018
    Mate I have sent u the link above to fix it. It is the best and safest way of doing It
  17. Praty_28 Jelly Bean Apr 16, 2018
    Praty_28, Apr 16, 2018 :
    Who says so? Have you ever flashed a rom via twrp? If one had to wipe internal storage nobody would use custom roms who has the time to copy 100's of GB's of data every single time you flash a new rom.
    Nicky_Wallace and Hydra Bob like this.
  18. Praty_28 Jelly Bean Apr 16, 2018
    You should try the unbrick tool now maybe some partition is corrupt. Unbrick tool should be able to fix any software related probelm.
    #38
    Nicky_Wallace likes this.
  19. Nicky_Wallace Froyo Apr 16, 2018
    #39
  20. keeratsawhney Froyo Apr 16, 2018
    keeratsawhney, Apr 16, 2018 :
    Actually There is New Security Encryption Of Oneplus in their Latest Release. Magisk and TWRP works by finding some loopholes in security patches. So If something went wrong while flashing it may make your device un bootable. So I would Recommend To Try This Method To Get Back Your Phone to Life, Thats a 100% Solution That I can provide with you here.
    I have personally been through this issue, I dint found solution over Internet, But I shall provide you with the best possible solution over at community which solved my problem Thanks :)
    #40
