I brick my OP5T
  1. keeratsawhney Froyo Apr 16, 2018
    keeratsawhney, Apr 16, 2018 :
    Also Make Sure You are Using Latest Version of TWRP, So That It Can Decrypt your Data !!
    #41
  2. AtZ_SpeKtruM Gingerbread Apr 16, 2018
    AtZ_SpeKtruM, Apr 16, 2018 :
    before using the unbrick tool i just want to make sure that i tried every methods
    #42
    Nicky_Wallace likes this.
  3. Nicky_Wallace Froyo Apr 16, 2018
    Nicky_Wallace, Apr 16, 2018 :
    Be careful as u do not want to **** it up completely. U should u tool then root again
    #43
  4. AtZ_SpeKtruM Gingerbread Apr 16, 2018
    yeah now i,m gonna use the unbrick tool i've already use it in the past to unbrick my op5t who was brick because of wrong twrp version since security patch
    #44
  5. shatadrusp Honeycomb Apr 16, 2018
    shatadrusp, Apr 16, 2018 :
    Format your internal storage from TWRP. Yes, there's an option for doing just that. After that just flash OOS full zip (not necessarily OOS) and it'll boot up just fine.
    PS: You can transfer the zip file from your computer to your device while you're in TWRP.
    #45
  6. AtZ_SpeKtruM Gingerbread Apr 16, 2018
    after i wipe everything except internal storage i loose the twrp recovery
    #46
  7. shatadrusp Honeycomb Apr 16, 2018
    No you don't lose TWRP. And I recommend you to 'Format Data'. There's the option to format data in the bottom side from where you wipe data.
    #47
    keeratsawhney likes this.
  8. keeratsawhney Froyo Apr 16, 2018
    Yes Format Internal Storage. You wont loose Recovery. This is the only solution.
    #48
  9. C1523866945809 Cupcake Apr 16, 2018
    C1523866945809, Apr 16, 2018 :
    true words
    #49
  10. Aathif_Mahir Ice Cream Sandwich Apr 16, 2018
    #50
  11. BuMaha Froyo Apr 16, 2018
    BuMaha, Apr 16, 2018 :
    lol my Hindi is weak so am saving this qoute to learn.
    #51
  12. kermex Honeycomb Apr 16, 2018
    kermex, Apr 16, 2018 :
    Did you knew the risk before you flashed a custom ROM?! I don't think so! Read, read, read and act!
    #52
  13. AtZ_SpeKtruM Gingerbread Apr 16, 2018
    i wipe everything except internal storage after that i succesfuly flash the official OTA but my phone does not want to boot and after 5min the phone restart in recovery mode but now i have the stock recovery from Oneplus
    #53
  14. shatadrusp Honeycomb Apr 16, 2018
    You didn't understand what I said.
    It'd be better for you if you visit a service centre and get your device fixed.
    #54
  15. AtZ_SpeKtruM Gingerbread Apr 17, 2018
    AtZ_SpeKtruM, Apr 17, 2018 :
    il thanks for all of you guys i finally unbrick my phone i just Factory reset with the stock recovery and my phone is back ! and i still have the bootloader unlock :)
    #55
    C1523866945809 likes this.
  16. theshinybeast Lollipop Apr 17, 2018
    theshinybeast, Apr 17, 2018 :
    Don't be ridiculous and don't give misinformation.o_O
    #56
  17. keeratsawhney Froyo Apr 17, 2018
    keeratsawhney, Apr 17, 2018 :
    I Tried My Self. My Problem Was Solved in Seconds. Try Everything And At Last When Nothing Lefts, Try My Method :)
    #57
  18. keeratsawhney Froyo Apr 17, 2018
    Anyways The Problem is Solved Though ;) Cheers
    #58
  19. AtZ_SpeKtruM Gingerbread Apr 17, 2018
    Yep thanks for your help guys :). Best One plus community
    #59
    Nicky_Wallace and keeratsawhney like this.
  20. theshinybeast Lollipop Apr 17, 2018
    You need to read up on what you're doing then. Pffftt
    #60
