i can not rind Call recording
  1. Xenomorph5354
    Donut Aug 1, 2018
    Xenomorph5354 , Aug 1, 2018 :
    I just discovered you can record calls on the OnePlus 5T and it's not in the call menu for me I'm located in Canada and it is legal to record calls here the only person bthat can record calls is the one in the conversation and they don't have to tell the other person so why isn't it enabled in Canada? we are not the US and their laws which say both people have to know the call has been recorded in Canada only 1 person has to know
  2. the_o2
    User of the Year 2018 Aug 1, 2018
    the_o2 , Aug 1, 2018 :
    Not sure the VPN you using is affecting your phone status or not, try to disable the VPN and reboot the phone and then check...
  3. Xenomorph5354
    Donut Aug 1, 2018
    the VPN isn't connected to anything online its an on device VPN that gets rid of ads on apps and websites
  4. the_o2
  5. the_o2
    Btw this is what the settings says here
  6. Xenomorph5354
    Donut Aug 1, 2018
    the_o2
    yes but that doesn't apply in Canada because here only 1 person in a phone call has to know it's being recorded for example I could record a phone call between me and you and not tell you I recorded the call that's legal in Canada In the USA it doesn't work like that that's why it's blocked in the US but I don't know why it's also blocked in Canada when we have more easier rules then theirs
  7. the_o2
    Ok then report this issue they would help you better..
    F_Mohamed_Salim_AKeP likes this.
  8. Jobin_jose__
    Gingerbread Aug 1, 2018
    Jobin_jose__ , Aug 1, 2018 :
    report it to the customer support as well. You may enquire with them whether this was a mistake or not.
  9. Horsault
    Nougat Moderator Aug 1, 2018
