I FIXED INSTAGRAM STORIES CROP AND I DON'T KNOW HOW
  1. iamlevik Eclair Apr 11, 2019
    iamlevik, Apr 11, 2019 :
    I tried every combination possible and I'm nowhere near as @aliciaa11 screen.
  2. Niklasg85 Gingerbread Apr 11, 2019
  3. mlllaaa Cupcake Apr 12, 2019
    mlllaaa, Apr 12, 2019 :
    Yeah, 6t is a little bit too long. When using gesture navigation it crops stories, but when you use the other two navigation bars it scales instagram better:
    vs. gesture navigation:
    It would be nice if OP fixed this problem somehow so we could use gesture navigation without cropping.
  4. iamlevik Eclair Apr 12, 2019
  5. Kytharsis Lollipop Apr 12, 2019
    Kytharsis, Apr 12, 2019 :
    It's up to Instagram, not OP.
  6. mlllaaa Cupcake Apr 12, 2019
    yes you're right. Instagram doesn't suppor OP 6t 's aspect ratio which is 19.5 : 9
  7. Kytharsis Lollipop Apr 12, 2019
    Yes, exactly.
  8. iamlevik Eclair Apr 13, 2019
    iamlevik, Apr 13, 2019 :
    But this person has the same issue, how come it doesn't work for his 6?
  9. iamlevik Eclair Apr 15, 2019
  10. iamlevik Eclair Apr 15, 2019
  11. Phanitp Froyo Apr 16, 2019
    Phanitp, Apr 16, 2019 :
    what is the version of your Instagram? are you on beta?
    It's so weird that Facebook story is fine but Instagram is not.
    Instagram:
    Facebook:
  12. aliciaa11 Cupcake May 5, 2019
    aliciaa11, May 5, 2019 :
    it seems like it's fixed on every OP6/6t? my bf's OP6 recently started showing non-cropped stories, and her sis's 6t too
    Does this apply for everyone?
  13. iamlevik Eclair May 5, 2019
    aliciaa11 likes this.
  14. nikerocker90 Cupcake May 30, 2019
    nikerocker90, May 30, 2019 :
    How is it all fixed? I have Oneplus 7 Pro, facing the same issue. Even when I click a photo using the front camera, the result is automatically zoomed in and cropped. What to do!?
  15. G_Shivam_Agrawal_xrqx Eclair May 31, 2019
    G_Shivam_Agrawal_xrqx, May 31, 2019 :
    i know the fix and using it for a while, it's quite simple. just in recent apps, go to three dot option of Instagram and enable fullscreen mode. No need to download mods.
    nikerocker90 and Brydges81 like this.
  16. Prioletts Donut Jun 10, 2019
    Prioletts, Jun 10, 2019 :
    I have an oneplus 6 and I keep seeing the stories cut off at the edges. I use gestures and the problem occurs both with instagram to "full screen" and also with "default".
    Any solution?
