3
I hate this phone already
  1. motherninja
    Gingerbread Mar 22, 2017
    motherninja , Mar 22, 2017 :
    Do not use the tempered glass protector for the phone with a 2.5D screen. I use the Ringke Invisible Defender to replace the factory installed screen protector and it's all fine after I wasted 2 of them (I bought the 3 + 1 packs).
    Seems like the phone itself, is not a problem, it's because u tried to install the tempered glass. Just don't use it and u should be fine.
    Currently, I rock my OP3T with Spigen Rugged Armor and I don't have any problems with it.
    #81
  2. G_anup_shrestha_Kwir
    Cupcake Mar 22, 2017
    #82
  3. elanglois
    Lollipop Mar 22, 2017
    elanglois , Mar 22, 2017 :
    Oh please STFU and go away. You are too incompetant to install the screen protector and you blame the phone? Know what? OnePlus already resolved that by preinstalling a protector on the phone before you got it. What did you do with the factory installed one?
    Never mind. Don't answer.
    I think OnePlus should Never Settle for moronic users and enforce an IQ test before buying
    #83
  4. smitha photos
    Eclair Mar 22, 2017
    #84
  5. Harry Tsang
    #85
  6. lostLambda
    lostLambda , Mar 22, 2017 :
    I think you just have a lack of mechanical ability.
    #86
    G_Harsh_Kothari_ocwV likes this.
  7. G_Harsh_Kothari_ocwV
    Froyo Mar 22, 2017
    #87
    lostLambda likes this.
  8. tornabene
    Cupcake Mar 23, 2017
    #88
  9. Jardani
    KitKat Mar 23, 2017
    Jardani , Mar 23, 2017 :
    Had 3t since February 4th, running fully naked (no case, no skin, no screen protector). You own the phone, not the other way around. It's a piece of equipment, that's all. Use it and chill out, don't worry about"protecting" it. All that does is it keeps it pristine for the next owner. All those accessories will run upward of $40-50 which is about what my phone will sell less for due to some light blemishes in few years. Except that I will actually have used the phone instead of freaking out and keeping it in a plastic and rubber slab with layers on top of layers that make it ugly as shit.
    #89
    zorkor and G_Harsh_Kothari_ocwV like this.
  10. G_何宇洋_wJPS
    #90
  11. mighty beast
    Froyo Mar 23, 2017
    mighty beast , Mar 23, 2017 :
    Bro, One Plus 3 T has curved screen display. If you had purchased full screen tempered glass, you can just massage the screen slightly so that air bubbles will be removed. While fitting the otter box case silica first layer please be extra safe such you are not disturbing the tempered glass. First few days it will be tough for you to Fit it. I use both and I don't have any issues.
    #91
  12. Aaron Stone
    #92
  13. cmitchellshaw
    KitKat Mar 23, 2017
    cmitchellshaw , Mar 23, 2017 :
    https://xkcd.com/1549/
    #93
  14. F_Tony_DeMartino_hjHI
    Ice Cream Sandwich Mar 23, 2017
    #94
  15. Kgisat
    Gingerbread Mar 23, 2017
    Kgisat , Mar 23, 2017 :
    Maybe go to a store and have them apply the screen protector if u cant do it in your own
    #95
  16. Deactivated User
    Mar 23, 2017
    #96
  17. vintagetech
    Honeycomb Mar 26, 2017
    vintagetech , Mar 26, 2017 :
    Yes, there is slight amount of the screen not covered on each side of the film.
    In my experience, it does not get scratched easily. I use a holster on my hip to hold my phone.
    #97
  18. vintagetech
    2.5D glass means that the edges are curved but not as drastically as the Samsung curve.
    #98
  19. 2pints
    Ice Cream Sandwich Mar 26, 2017
    2pints , Mar 26, 2017 :
    Screen protectors can be a right pain in the rear at time to install, if you have a dust problem ( ie you live in a house with carpets) try installing it in the bathroom.
    if you need more sticky labels, use some adhesive tape instead
    I'm using an orzly tempered glas screen protector with the oneplus 3 flip case and they both play well together, however theres a slight ridge at the sides of the protector.
    one thing to note, is that under certain lighting conditions you may also get a rainbow effect, i notice it under Flourescent tubes, CFL lamps, but not incandescent, halogen or LED
    #99
  20. Rumpelstilzchen77
    Gingerbread Mar 26, 2017
    Rumpelstilzchen77 , Mar 26, 2017 :
    I use the manufacturer installed screen protector and black NILLKIN slim case. It looks really cool and there never was any bubble.
