4
I have issues with my alarm clock
  1. crj9lr
    Donut Jan 27, 2022
    fadthemisss likes this.
  2. Ilduce77
    Cupcake Jan 27, 2022
    Ilduce77 , Jan 27, 2022 :
    The same problem for me...
    The clock view doesn't appear when the alarm go off.
    I also have problem with bubbles. Before, when I was talking in the phone via Bluetooth headset and at the same time did other things with my phone, like browsing internet or typing messages, a floating bubble appeared on the screen, with shortcuts to hang up, activate/deactivate the microphone and change between speaker/phone/headset.
    That bubble is now long gone and I can only reach hang up and deactivate microphone trough the notification curtain.
    Bubbles and alarm view worked fine for a week after EU-versions got the C44-update. But then I went back to not work..
    If I search for bubbles and go to phone and clock, the option "bubbles" are there, but I can't change anything, all sliders are grey..
    Icons on the aod is sometimes smal and white an sometimes in color and big...
    This merge with color os is crap.
  3. fadthemisss
    Gingerbread Jan 27, 2022
    fadthemisss , via OnePlus 9 Pro , Jan 27, 2022 :
    I had do all that things before I make the decision for factory reset
  4. fadthemisss
  5. Ilduce77
    This is the bubble I talked about before...
    The alarm view and this bubble came back after rebooting.. I'll see for how long it lasts...
    A day or two for some users I read..
  6. Luis_Henriques74
  7. W1617299376507 , via OnePlus 9 Pro , Jan 27, 2022 :
    I also made a factory reset mainly due to 5G not working, but that lead me to a fresh new hell. Initial setup crashed, my Google account was FRP locked and with magic and wizardry I rolled back to latest A11. Not going to try A12 anytime soon. Might sell my phone or feed it to ducks, maybe going back to Xiaomi.
    fadthemisss and G_V._M._sKKA like this.
  8. Ilduce77
    Cupcake Jan 28, 2022
  9. marcber3
    Donut Jan 28, 2022
    marcber3 , Jan 28, 2022 :
    I did the Factory reset, at the begginig It worked. But todays morning after having the phone in charge this night, again is not working. Is It working for you?
  10. Bundesgabbo
    Bundesgabbo , Jan 28, 2022 :
    My solution was to turn on AOD - and turn off every possible function and change to another clock design. After that turned off AOD and it worked for me.
  11. marcber3
    Donut Jan 28, 2022
    Yes i tried too, but not worked. Honestly no idea what else i can do, but it's desperate... And i don't want to do factory reset again
  12. Filogo
    Eclair Jan 28, 2022
    Filogo , Jan 28, 2022 :
    The problem seems to disappear randomly. I've same strange behaviours in other apps like the Phone App with floating bubble disappearing and then sometimes appearing again. I tried factory resetting but the matter has to be with the permission management system that is heavily bugged.
    OnePlus should do something soon because the user experience in Oxygen OS 12 is not acceptable. This kind of problems should have been evident if the system was tested before releasing a stable version.
    crj9lr likes this.
  13. crj9lr
    Donut Jan 29, 2022
    Filogo likes this.
  14. Filogo
    Eclair Jan 29, 2022
    Filogo , via OnePlus 9 Pro , Jan 29, 2022 :
    I found that after the reboot of the phone the issues disappear then after some optimization of the OS breaks the ability to display the screen of the apps that have to have priority in the UI. Restart always resets the behaviour. Still trying to figure out what is the service that breaks all.
    crj9lr likes this.
  15. crj9lr
    Donut Jan 29, 2022
    Filogo likes this.
  16. G_V._M._sKKA
    Froyo Jan 29, 2022
    G_V._M._sKKA , via OnePlus 9 Pro , Jan 29, 2022 :
    Also i found that the sleeping mode options in the well beeing section are interesting.
    That could also lead to show 1 schedule in the do not disturb menu even if you cannot see any there...
    Filogo likes this.
  17. Filogo
    Eclair Jan 29, 2022
    I saw this glitch too. It seems the Oxygen OS options overlap with the digital wellbeing app options in some way. I'll give it a try disabling the digital wellbeing app options.
  18. Ilduce77
    Cupcake Jan 29, 2022
    #38
  19. G_V._M._sKKA
    Froyo Jan 29, 2022
    #39
    Filogo likes this.
  20. M1587745464586
    Cupcake Feb 2, 2022
    M1587745464586 , Feb 2, 2022 :
    Disable display on status bar helped
    #40
