i have problem for one plus 6 screen colour
  1. X1536252195010
    Cupcake May 29, 2019
  2. Priyanshu Sharma
    Jelly Bean May 30, 2019
    Kytharsis likes this.
  3. X1536252195010
    Cupcake Jun 5, 2019
  4. Priyanshu Sharma
    Jelly Bean Jun 5, 2019
  5. X1536252195010
    Cupcake Jun 5, 2019
  6. X1536252195010
    Cupcake Jun 5, 2019
  7. Kytharsis
    Marshmallow Jun 5, 2019
    Kytharsis , Jun 5, 2019 :
    You might be better off describing your problem in your native language... your English is difficult to understand.
  8. X1536252195010
    Cupcake Jun 5, 2019
  9. X1536252195010
    Cupcake Jun 5, 2019
  10. Duckpond50140
    Cupcake Oct 19, 2019
    Duckpond50140 , Oct 19, 2019 :
    So I found the way to fix the screen colour problem on the 6T.
    Go to Settings - System - Accessibility - Colour Correction.
    Turn Colour Correction OFF
    Then also check Reading Mode under Settings - Display and make sure that is turned OFF as well.
    This should reset your screen colors to normal.
    You're welcome!!!
