I have unlocked bootloader, is there any way to root op3 without pc?
  1. Anonymous B-)
    Gingerbread Sep 20, 2016
  2. acharyarev
    Ice Cream Sandwich Sep 20, 2016
    acharyarev , Sep 20, 2016 :
    Since you have unlocked bootloader you won't need pc to root just flash the right super su
  3. Anonymous B-)
    Anonymous B-) , Sep 20, 2016 :
    I have unlocked bootloader, but I am on stock recovery.
  4. locxFIN
    KitKat Sep 20, 2016
    locxFIN , Sep 20, 2016 :
    Then no. You can install TWRP only if you are already rooted or via fastboot.
    cezarvrabie likes this.
  5. Funk Wizard
    Moderator Moderator Sep 20, 2016
    Funk Wizard , Sep 20, 2016 :
    Just download install a custom recovery and flash supersu to install the custom recovery via fastboot you need a pc or a machine
  6. aj7400
    aj7400 , Sep 20, 2016 :
    Yes there is a way, there is a app which can be used to flash recoveries...
    There was an app i used on opx ( kingroot)
    It used to root my phone without pc just by installing the app
    Anonymous B-) likes this.
  7. Anonymous B-)
    I dont have pc
    I tried to flash recovery via fastboot(my friend's pc) but my op3 is not getting detected (installed the drivers)
  8. Funk Wizard
    Try some other machine preferably with windows 7 for easy installation and fastboot flash
  9. Pot Noodle
    Pot Noodle , Sep 20, 2016 :
    Does Kingroot work with the op3?
  10. aj7400
    I have never tried but apparently it should work .
    You can try
  11. F_Valentin_Bacquet_FFVt
    Cupcake Nov 20, 2016
    F_Valentin_Bacquet_FFVt , Nov 20, 2016 :
    Hi, I wanna know how can I root my OP3 without PC or TWRP, I've try KingoApp and KingRoot and it's not working, if you have an apk for OP3 plz share here !
  12. F_Tomasz_Zakościelny_zv
    Honeycomb Nov 20, 2016
    Salt505 likes this.
  13. Tokolozi
    The Lab Reviewer - OPPO Find N Nov 20, 2016
    Salt505 likes this.
  14. Vishal_pipal
    Froyo Nov 20, 2016
    Vishal_pipal , Nov 20, 2016 :
    Bro, it's impossible to root without PC, believe me I have tried a lot of times didn't work at all, so just see some official tutorials by oneplus on YouTube to learn how to root.
    Cheers
    Salt505 likes this.
  15. theshinybeast
    Marshmallow Nov 20, 2016
    theshinybeast , Nov 20, 2016 :
    This^
    @F_Valentin_Bacquet_FFVt
    It's not really a good idea to use King root etc , if something goes wrong, which sometimes happens, you'll be in double trouble because not only will you have a bricked phone but also you're going to need a PC to fix whatever is broken.
    So as has been mentioned above better to borrow / use a friend's PC .
    PTuT, SoniaB, josefn24 and 1 other person like this.
  16. dsmonteiro
    OnePlus Community Team Staff Member Nov 20, 2016
    dsmonteiro , Nov 20, 2016 :
    And kingroot is shady as hell.
    PTuT, ghostofcain, SoniaB and 3 others like this.
  17. F_Valentin_Bacquet_FFVt
  18. Tokolozi
    Tokolozi , Nov 20, 2016 :
    It is advised to fix problems instead of finding workarounds for them
    ghostofcain and theshinybeast like this.
  19. josefn24
    Jelly Bean Nov 20, 2016
    josefn24 , Nov 20, 2016 :
    You want to have twrp because it will make your life so much easier if you get bootloops or brick your phone in any way. You can easily make backups and restore your previous app data and settings. If you don't already know all of this then go and so it properly or you will wish you had in the first place. This is one complete guide from people that took a lot of time.
    Https://forums.oneplus.net/threads/...wrp-root-nandroid-efs-backup-and-more.448149/
    There also videos on YouTube from OnePlus and others as well.
  20. Bartnl
    Lollipop Nov 20, 2016
