I need help on my galaxy y please.
  1. Evan Retiere
    Froyo Jun 12, 2014
    Evan Retiere , Jun 12, 2014 :
    Hi,
    i instal a rom on my galaxy y gt s5360 but now he restart again and again. i don't have acces to recovery. pls help me
  2. RogueS4
    Jelly Bean Jun 12, 2014
    RogueS4 , Jun 12, 2014 :
    You should be able to get into recovery
    Try this
    • Power off your device and wait for 5-10 seconds until the device is fully switched off.
      └ This is completely optional. You can choose to keep the device switched On if you wish to
    • Press and hold ‘Volume Up + Home + Power’ buttons together and release them as soon as you see the Galaxy Y logo on your phone’s screen.
    • Your phone will boot into recovery mode. Use Volume buttons to navigate Up and Down between options and use Power button to select an option in recovery.
  3. slimgym20
    Ice Cream Sandwich Jun 12, 2014
    Evan Retiere likes this.
  4. Evan Retiere
    Froyo Jun 12, 2014
  5. memeroot
    Gingerbread Jun 12, 2014
  6. mikeyfrog
    mikeyfrog , Jun 12, 2014 :
    See if it gets to the point where it will connect to ADB, most phones do during the boot at sometime. when you hear it connect on your computer, do "ADB reboot recovery" command in the windows command prompt.
    chakakhan and Evan Retiere like this.
  7. Evan Retiere
    Froyo Jun 12, 2014
  8. mikeyfrog
    I suggest you keep calm and get a new phone then, you might have a paperweight on your hands.
  9. RogueS4
    Jelly Bean Jun 13, 2014
    RogueS4 , Jun 13, 2014 :
    Found this on xda http://forum.xda-developers.com/showthread.php?t=2181376&page=5
    Finally i restored back my SGY without going to service center..
    Tried several combos and got back my SGY.. Try this if you have same problem...
    Combo 1
    1. Flash with ODIN v3.07(Stock Rom Any region)
    2. only(PDA , CSC , Modem along with PIT file)
    After finishing Combo1 Check of download mode is Working If yes Combo 2
    Combo 2
    1. again Flash with ODIN v3.07(Same stock Firmware used in Combo 1)
    2. now only(Bootloader , CSC , Modem ,PDA) No PIT File(Important)
    After finishing See your SGY it boots up normally And finally Enjoy...
    Use this PIT
    totoro_0623.rar
    mikeyfrog likes this.
  10. ChristiCarr
    Honeycomb Jun 13, 2014
  11. Mühlberger
  12. chopchopw
    Ice Cream Sandwich Jun 13, 2014
  13. mikeyfrog
    mikeyfrog , Jun 13, 2014 :
    indeed, but odin is something scary for most people, especially the warning on the phone when you put it in download mode!
  14. chopchopw
    chopchopw , Jun 13, 2014 :
    oh honestly don't worry. I installed gs3 rom on note 2 before by mistake (faulty OTA) and then odin bam everything is good. its honestly download rom plug in and go 10 min tops
  15. av78130
    av78130 , Jun 13, 2014 :
    might have to do a factory restore of the default img on the phone. Can't remember if its possible but maybe sideload a recovery. Either way XDA-Developers members are your friends in situations like these.
  16. nappadang
    Gingerbread Jun 13, 2014
  17. ryaldo
  18. Evan Retiere
    Froyo Jun 13, 2014
