C1639247853364 , via OnePlus 9 , Jan 26, 2022 : I have recently updated my OnePlus 9 5g phone with big update around 4GB size. But after that I unable to dismiss alarm from the lock screen. How can it be resolved.
C1639247853364 , via OnePlus 9 , Jan 26, 2022 : Hi all, actually it worked after check , uncheck notification settings in alarm settings. After that I restarted my device. And it's working now.
ghostofcain , Jan 26, 2022 : So ask the mods to mark this solved, and do bear in mind in future, issues with releases should be addressed in release threads.
C1639247853364 , via OnePlus 9 , Jan 27, 2022 : Hi, It is not working again. Today morning not shown pop-up on lock screen to dismiss alarm. Issue still persist. Please fix this bug as soon as possible. I didn't expected these kind of bugs from OnePlus. I purchased OnePlus because of his performance and features but it seems have many issues with it.
C1639247853364 , via OnePlus 9 , Jan 27, 2022 : It was truly irritating in the morning to unlock phone and pull notification drawer and then dismiss alarm
The1Lion , Jan 27, 2022 : Is it only happening while plugged into a charger? I noticed similar issue on my OP9, seems to be when the phone is plugged into the charger I have to actually do more to Snooze or Dismiss.
Anish_Ag , via OnePlus 9 Pro , Jan 27, 2022 : I am experiencing the same issue with my OnePlus 9 Pro. Please fix this issue asap.
aneblett , Jan 28, 2022 : I'm also experiencing this. I hate the new update but this issue really sucks. I don't want to have to get into my phone to turn my alarm off, it wakes everyone up when I just need it to be me. Because by the time I log into the phone and open the clock app, the volume is all the way up on the alarm.
V1643481319332 , Jan 29, 2022 : Cannot close alarm either. Before come slide bar to dismiss alarm, but now nothing. Only thing that works is go to alarm settings and close alarm .... And another big thing is that the battery life getting even worse after new update. I have changed the settings as those were before and closed all no needed programs and battery is getting empty about 3 hours earlier than previous software version
keshavpittie , Jan 29, 2022 : Hey lock the clock application in the recent apps and do not close it. The above worked for me Im using oneplus 9 pro on oxygen os 12 c.44
V1643481319332 , Jan 30, 2022 : Lock the clock application? I do not have that kind of option on my settings. Same phone and same sw
M1637702319240 , via OnePlus 9 Pro , Jan 30, 2022 : Hello, I have erased all data from Clock app and it works, but still not working when tha phone is switched off.
keshavpittie , Jan 30, 2022 : Its available in recent apps. Click 3dot then lock option in recent tabs
BullshitPingu , via OnePlus 9 Pro , Feb 6, 2022 : Got it fixed by switching to the Google clock app and disabling battery optimization in settings for the app (Settings > Battery > Advanced Settings > optimize battery usage > Select clock app > switch to do not restrict). The OnePlus clock app is not listed there so it probably cannot be resolved for the OnePlus app by this way.
Hammer4all , via OnePlus 9 Pro , Feb 9, 2022 : I have the same problem. After a night's sleep I can't dismiss. Tried during day, then it works. This is obviously a bug that came with the update Android 12 vs. OnePlus clock app. OnePlus, please investigate!
ghostofcain , Feb 9, 2022 : By happenstance, you just so happen to have posted your observations to a thread on this very issue. I wonder if you considered READING the thread before posting, if you had maybe one of the solutions might have saved you from having to post.
Hammer4all , via OnePlus 9 Pro , Feb 9, 2022 : I READ all posts, just wanted to confirm + I actually had some additional information if you READ my + all other posts.
ghostofcain , Feb 9, 2022 : Sorry, for some reason I'm still only seeing one post from you on this thread. I assume you've tried the solutions suggested, in this thread, and they haven't worked?
