i updated my OnePlus 7pro
  1. L1534631888415
    Cupcake Feb 20, 2020
  2. pablofg1978
    Spanish POC Assistant Head Moderator Feb 20, 2020
    pablofg1978 , Feb 20, 2020 :
    Most likely your notes are gone, next time use Google keep, it will be saved on the cloud
    otto2, the_o2, THBMB and 1 other person like this.
  3. I1574272408267
    Cupcake Feb 25, 2020
  4. Swejuggalo
    KitKat Feb 25, 2020
    Swejuggalo , via OnePlus 7 Pro , Feb 25, 2020 :
    This may be better fitted into this thread.
    https://forums.oneplus.com/threads/oneplus-7-pro-battery-heating-feedback-thread.1031989/
    Don't forgett to post both app and full device battery stats after consuming approx 50%.
    Also give it a day or 2 preferably by charging over night to let the device fully optimize.
    Sometimes the drain makes sense. Normal causes can be some app that either is faulty or actually do what it is told to do that adds drain. Sometimes it's simply a fresh update that needs to settle in (optimize).
