72
IDEAS - How does your idea flow within OnePlus
  1. Sridevi_V
    Cupcake Mar 21, 2020
    #41
    W1585050687104 likes this.
  2. G_harsh_kadian_
    G_harsh_kadian_ , via OnePlus 7 Pro , Mar 21, 2020 :
    Hi there Oneplus hope you are doing great. I'm a oneplus 7 pro user and i will be so happy if you give always on display feature to the oneplus device. Thanks for having our ideas
    #42
  3. Godfather 1
    Jelly Bean Mar 21, 2020
    #43
    Nicola Ferraro likes this.
  4. Prathee918
    Prathee918 , Mar 21, 2020 :
    I guess this would be an software implementation on the camera part. Would like to see the nightscape mode enabled for the front facing camera. Even though there is screen flash available it cannot be the right option at all the scenarios. Whereas while there is descent lighting but just to get a better image nightscape gets into action. Hope you consider this and it is not much complicated one i believe as some in the market provide night mode or whatever they call for front facing camera and some even enable it for videos i dont know how it works on a video part. But for snaps it would really be an added advantage.
    #44
  5. U1564572068513
    #45
  6. Last edited: Mar 21, 2020
    #46
  7. Sudhakar53
    Donut Mar 21, 2020
    Sudhakar53 , via OnePlus 7T , Mar 21, 2020 :
    I just need a very important function which is even present in every other phone instead of my OnePlus 7T i.e. delete option for messaging app direct from notification shade.
    currently there are only 2 option as one is reply and mark as read. what about delete directly from there?
    attached is screenshot for the reference.
    #47
  8. Sudhakar53
    Donut Mar 21, 2020
    As in my OnePlus 7T,there is amoled display so why not we have an option to enable AOD(Always On Display).
    which may work with very little impact on battery like samsung amoled devices have.
    #48
    sukendar_reddy likes this.
  9. Sudhakar53
    Donut Mar 21, 2020
    One more request guys :
    As in Honor devices(Now also on Xiaomi POCO F1), if any notification came and it will display only icon of the app with encrypted message AND only after successful faceID verification, it shows content of the notification on lock screen.
    Please make this functionality for Oneplus devices too as it is very beneficial for users.
    I am missing my Honor Play only for this functionality.
    #49
  10. SaChan2019
    Froyo Mar 22, 2020
    #50
  11. F_Vladislav_Pershenkov_F , via OnePlus 7T Pro , Mar 22, 2020 :
    Hi everyone. Very dark display on OP 7 T Pro even in time with adaptive light on. Need change adaptive brightness on lowest level few digits up. When is dark and nearly dark adaptive light working bad but in day time and outside working very good.
    #51
  12. Chirag_Gohil
    Honeycomb Mar 22, 2020
    Chirag_Gohil , via OnePlus 7T , Mar 22, 2020 :
    scope of improvement:
    1. camera : Slow-motion its bad. lines lines coming while it was opening.
    2. VoLTE : icon size decrease bcz it is taking much space.
    3. Clear App : junks , Catches and unwanted files must be removed of one click.
    4. Notification light : not available in my phone 7T Notification light so you must be provided Edge to Edges notification ( Unique and different colours)
    5. icon : after the Beta 1 update i lost oxygen icons packs and all others packs. you must be improved it. no any icons packs lost.
    6. Words & Excel and PPT : this files not support , i mean it will be dependent of 3rd party aaps. you must be built it. and provide bcz this was helpful . 3rd party apps sometimes not support and many more problems create.
    7.
    #52
  13. Surajsagar1
    Cupcake Mar 22, 2020
    Surajsagar1 , via OnePlus 7 Pro , Mar 22, 2020 :
    the oxygen beta 11 has many bugs and problems and that i can explain no.1 i installed beta 11 and after that my system font size has increased no.2 you can note fix it by your self
    #53
  14. MAPID , via OnePlus 6T Midnight Black , Mar 22, 2020 :
    RESET BUTTON ON STEP COUNTER
    reset button is highly needed in the step counter .. it help the user to get the correct steps taken and distance covered in a limited period of time.. it will help in tracking the speed of his walking or jogging
    #54
  15. agosthi2
    Eclair Mar 22, 2020
    #55
  16. rahulopg4267
    Froyo Mar 22, 2020
    #56
  17. K1560976949282
    Donut Mar 22, 2020
    K1560976949282 , via OnePlus 7 , Mar 22, 2020 :
    AI camera
    improve camera software to detect and improve color quality as per object like if a plant is present then improve saturation of green and other textures according to nature of objects
    #57
  18. Parvezahmed9081
    Eclair Mar 22, 2020
    #58
  19. Q1574504963681
    Donut Mar 22, 2020
    Q1574504963681 , via OnePlus 6T , Mar 22, 2020 :
    I want give an idea ,that haptic feedback in one plus devices should more stronger ,just like an iphone which gives you feedback when u accidently touch anything the feedback it gives , i know it is present in oneplus ,coz when changing filters in instagram it does gives the same as iphone the feedback. ,kindly consider
    #59
  20. Q1574504963681
    Donut Mar 22, 2020
    #60
