72
IDEAS - How does your idea flow within OnePlus
  1. ekansh_shukla8
    Gingerbread Mar 27, 2020
  2. sigafdo07
    Eclair Mar 28, 2020
  3. Shathiz
    Donut Mar 28, 2020
    Shathiz , Mar 28, 2020 :
    Since my oneplus 7T lacks a notification led, the only way to know the battery percentage charged while its plugged in is via google assistant ambient mode. I think just a small bar maybe around the notch or bottom of the screen indication the battery percentage charged is much needed here. Atleast a virtual dot which changes color based on the battery percentage charged would be nice. These alternatives are much minimal compared to the heavy google assistant ambient mode.
  4. Shathiz
    Donut Mar 28, 2020
    I suggest that the volume bar has quite some dead space that can be minimized for better content viewing while adjusting the volume. The icons(circled in the screenshot) can also be minimized.
    Srínívas Sñ and Atmik123 like this.
  5. aabujarad
    Eclair Mar 28, 2020
    aabujarad , Mar 28, 2020 :
    Is it possible you make a phone like oneplus 7pro with flat screen and smaller size like 6 icnh :)
    believe me many people wish if you do this, I will be the first buyer
  6. hmswrth
    Gingerbread Mar 29, 2020
    hmswrth , via OnePlus 7 , Mar 29, 2020 :
    Feature Request : wireless earphones volume buttons to capture images in the camera app!
    It's really shocking that OP missed this little feature BUT it's a really productive one atleast for the shutter bugs. Please do implement this feature. Right now it works for wired earphones but doesn't work with Bluetooth earphones.
  7. dhames
    Gingerbread Mar 31, 2020
    dhames , via OnePlus 5T , Mar 31, 2020 :
    It's a small suggestion, can we have ring and notification volume control separately, it's kind of annoying if we crank up the ring volume, notification bugs all the time
    hemanth_mudra likes this.
  8. A1559154472807
    Donut Apr 2, 2020
    A1559154472807 , Apr 2, 2020 :
    I would welcome a replacement of the alert-slider from the side to the top!
    I do not use a fixed protective cover for my smartphone. I put it in a perfectly fitting pocket. When inserting the switch is often accidentally pushed up and muted. If the switch were on the top, this problem would be solved. In addition, you could mute the ringtone through the open pocket in the case of a call without having to pull the device out of your pocket.
  9. Tomonesh87
    Cupcake Apr 2, 2020
    Tomonesh87 , via OnePlus 6T , Apr 2, 2020 :
    We want some entertainment features in our OnePlus phone like animoji .We don't want to download any extra app for use to make funny video ..Plzz bring some interesting features like animoji .
    "NEVER SETTLE"
    W1549057076643 likes this.
  10. Yatish R
    Cupcake Apr 3, 2020
    Yatish R , via OnePlus 7 Pro , Apr 3, 2020 :
    bro,camera is good. Its usable not too good not too bad .Not the worst not or the best,for every day use its good (great).
  11. X1582748018080
    Cupcake Apr 5, 2020
    X1582748018080 , via OnePlus 7T Pro , Apr 5, 2020 :
    as there are no applications accessible to the public it would be nice to have the possibility to see the frame rate on the game screen !! because it is very useful and sought after for players and I hope it will be taken into consideration as it should not be difficult to implement and would be appreciated by every oneplus player
    V1564975651493 likes this.
  12. hechemtommy
    Cupcake Apr 6, 2020
    hechemtommy , via OnePlus 7 Pro , Apr 6, 2020 :
    -it will be cool if we have the option to adjust the blur of a portrait image after shooting it.
    -the transition when changing lenses from wide to zoom and ultra wide is laggy, it can be smooth and it will look cooler
    -add a video portrait mode like the one instagram and google duo using.
  13. hechemtommy
    Cupcake Apr 7, 2020
    hechemtommy , via OnePlus 7 Pro , Apr 7, 2020 :
    animations : animations define the mobile's smootheness, why don't use the stock pixel's animations ! they're not so fast like the ones on oneplus yet they look smoother!
  14. D.Sai Suhail Baba
    Jelly Bean Apr 12, 2020
    D.Sai Suhail Baba , Apr 12, 2020 :
    It will be better if OnePlus introduce it's own security management app to lock and protect customer privacy and also device from intruders and implement cloud service option in security app to protect cloud storage data.
    Features I want to suggest:-
    1. Should have Security Management app for privacy.
    2. OnePlus music app.
    3. OnePlus share app like Shareit, air drop, Share me etc..,
    4. Add emojis and filters in camera app like iphone, Xiaomi devices etc..,
    OnePlus share app should have features like receiving files from Shareit also if the other device is not supported OnePlus share it should have feature to accept files from Shareit, air drop etc..,
  15. Z1580897002885
    Cupcake Apr 20, 2020
    Z1580897002885 , Apr 20, 2020 :
    you can add call reminder feature. it shall allow us to dial a contact or number at a specific time on a specific date.
    it is a very important feature for follow ups/reminders
  16. ktanvir10
    Cupcake Apr 21, 2020
    ktanvir10 , via OnePlus 6 , Apr 21, 2020 :
    Hi Oneplus Team,
    I have a suggestion for adding some feature:
    1. Parallel Apps: add application option for customize.
    2. Add Fingerprint/Password/Pattern lock option for Power off.
    Thanks in Advance
    Love form Heart [e]2764[/e]️[e]2665[/e]️[e]2665[/e]️
    reqwo and Chrisjk like this.
  17. Nicola Ferraro
    Eclair Apr 24, 2020
    Chrisjk likes this.
  18. Chrisjk
    Eclair Apr 25, 2020
    Nicola Ferraro likes this.
  19. Shubham jitendra bandal , via OnePlus 7 , Apr 25, 2020 :
    Junk files cleaner , those uninstall app remaining there files due to this phone storage get extended and phone lagging due to unwanted code, (Oneplus should have their own video player ) to Playing video something cool.
    Chrisjk likes this.
