5
I'm not able to qr code scanner options in camera settings after updated Android 11 via OnePlus 7
  1. HarshilVasani4
    Donut Mar 30, 2021
    HarshilVasani4 , via OnePlus 7 , Mar 30, 2021 :
    Hi there,
    After updated os Android 11 I'm not able see qr code scanner in camera in one plus 7
    any one can help me
    Thank You
  2. derLenno
    The Lab - OnePlus 6 Reviewer May 20, 2021
    Best Answer
    derLenno , May 20, 2021 :
    Here is a useful answer:
    The QR code scanner is not part of the camera app anymore since Android 11, independent of the device. This is by design.
    Solution: The easiest way without installing any 3rd party apps is to click the Google Lens icon (next to the shutter icon) and use Google Lens to scan the QR code. It might not be available regionally, in that case, Google Lens still is the easiest and most natural option for that.
    Bouncer71, Arfannn and McJader like this.
  3. firdaauuss
    Donut Apr 3, 2021
    HarshilVasani4 likes this.
  4. A1574159815266
    Cupcake May 16, 2021
  5. Woll
    Cupcake May 19, 2021
  6. KaranFafat
    Honeycomb May 20, 2021
    KaranFafat , via OnePlus 7 , May 20, 2021 :
    Why download another crappy app when OnePlus has provided the scanner in their camera itself. It's their job to get it fixed and not ours to compromise and use other applications
    saf.alk likes this.
  7. Woll
    Cupcake May 20, 2021
    Woll , May 20, 2021 :
    Depends do u want to scan qr codes now or do u complain about it but ok they Will need to fix it but u tot a temporaly fix
  8. Petvetus
    Cupcake May 30, 2021
    Petvetus , May 30, 2021 :
    I'm facing same problem, after last update to android 11, I am not able anymore to scan any Barr codes with my OP 7 phone. It is really annoying because I used to do pay all my business and personal bills using the phone to scan Barr codes from the invoices. I am using One plus since One plus 2 model, now I have OP 7, but if they will not fix this really soon, I am thinking to change the phone company with my next phone update.
