I'm very disappointed with OnePlus 6
  1. Vinodrvd91 Cupcake May 23, 2018
  2. SomeSayImHandS0me Honeycomb May 23, 2018
  3. meatandy Oreo May 23, 2018
    meatandy, May 23, 2018 :
    Try with the ambient display toggled off.
  4. F_Guru_Moorthy_Ganesh_lV Gingerbread May 23, 2018
  5. posco Donut May 23, 2018
    posco, May 23, 2018 :
    There is a 10 day replacement policy. Just raise a request online with the order and they will take care of it.
  6. punitvaria Ice Cream Sandwich May 23, 2018
  7. Terryruiz Ice Cream Sandwich May 23, 2018
    Terryruiz, May 23, 2018 :
    I've been waiting for a few thoughts on the OnePlus 6 before I jump from my OnePlus 5 .....Ive decided to stick with my OnePlus 5 and see what 6t or 7 is like
  8. Chriiis Gingerbread May 23, 2018
    Chriiis, May 23, 2018 :
    I had the same problem with my 3T back in the days. Solved after an update........
  9. Zombie Feynman Froyo May 23, 2018
    Zombie Feynman, May 23, 2018 :
    It looks like you are indoors, so although you can see pretty well there is probably not that much light. The eye is pretty awesome in adapting to very different light levels.
    Slow motion video is hard, because you have to capture a lot of frames per second, and that means that you have very little time for each one. In your captures, you are trying to record at 240 and 480 fps. That means that the camera has at most 1/240s (or 1/480 in 720p) for each frame. That's a short time, so you don't get much light in the sensor. The camera compensates by raising the sensor sensitivity (the ISO), which makes the image brighter, but it amplifies both the image data and the noise so the image loses quality and you see that as blurriness.
    If you take a photo in the same conditions and check the image metadata you will probably see a shutter speed around 1/20 or 1/10, which means that the camera had 10 to 20 times more time to gather light. But if you use those shutter speeds then you can't do slow motion video because each frame takes too much time.
    Slow motion video needs a lot of light, so you will have a lot more luck outdoors. If you want to do it indoors I would try a video of something small with a light really close by (something like a desk light).
  10. Vinodrvd91 Cupcake May 23, 2018
    Vinodrvd91, May 23, 2018 :
    I totally agree with you. I checked with bright light and it works fine.
  11. tempest301 Cupcake May 23, 2018
    tempest301, May 23, 2018 :
    I noticed the same issue, in a room full of light, the video comes out dark
  12. The_Unkown Jelly Bean May 23, 2018
    The_Unkown, May 23, 2018 :
    You must have 10 days replacement policy with Amazon , go to your order and raise a request for replacement on the basis of hardware malfunction. They will take care of that. Do that instantly because you have only 8 days left
  13. F_Guru_Moorthy_Ganesh_lV Gingerbread May 23, 2018
    F_Guru_Moorthy_Ganesh_lV, May 23, 2018 :
    yes I applied today technical support Engineer came and analysis my problem. in few days I got new OnePlus 6 Device
    The_Unkown likes this.
  14. Vinodrvd91 Cupcake May 23, 2018
    how can I apply for checkup?
  15. F_Guru_Moorthy_Ganesh_lV Gingerbread May 23, 2018
    just complaint about ur problem Amazon automatically arrange technical support Engineer within 24 hrs
  16. shubhamsingh55 Honeycomb May 23, 2018
    shubhamsingh55, May 23, 2018 :
    just replace the device!!
    Tell Amazon that ur display is not working and heating like anything..
    then he will say to install phone check app.. so u tell them that ur device toutch is not even working so how u can install any app..
    u will definitely get a replacement unit.. i can promise u that..
  17. The_Unkown Jelly Bean May 23, 2018
    good . now rest and use your device for ultimate performance , get android p on it , enjoy the flavour of upcoming phone til you have it !
  18. Vinodrvd91 Cupcake May 23, 2018
    Android p for OP6? when?
    #38
  19. The_Unkown Jelly Bean May 23, 2018
    #39
    Vinodrvd91 likes this.
  20. Vinodrvd91 Cupcake May 23, 2018
    #40
