IMEI Code starts with 99
  1. U1609690407679
    Cupcake Jan 26, 2021
    U1609690407679 , Jan 26, 2021 :
    Hi! I have bought Oneplus 7T from Amazon. Now, I have noticed that I have two IMEI that are identical and starts with 990015...... I have read that this phone is not in the international IMEI database. Is it possible to get a normal IMEI?
  2. Tokolozi
    Most Original Avatar Jan 26, 2021
    Tokolozi , Jan 26, 2021 :
    Amazon.in is the official reseller of oneplus, are you located in India?
    However if your EMEI's for both sims are the same it could be that you have flashed T-Mobile variant.
    You cannot change EMEI codes since they are hardware identifiers of a device.
    drl431 likes this.
  3. drl431
    Community Hero 2020 Jan 26, 2021
    drl431 , Jan 26, 2021 :
    Hi, you bought a used carrier variant that has been converted to a global model. Amazon is a platform that any reseller can use, as well as amazon itself.
    rhyd1am and Tokolozi like this.
  4. Helder_DAlmeida
    Lollipop Jan 26, 2021
  5. Tokolozi
    Tmobile models have two identical ones since officially they can't work on other networks.
    the_o2 and Helder_DAlmeida like this.
  6. Helder_DAlmeida
    Tokolozi likes this.
  7. Tokolozi
    Helder_DAlmeida likes this.
  8. Helder_DAlmeida
    Helder_DAlmeida , via OnePlus 7T , Jan 26, 2021 :
    If you are telling me I believe it, but I find it very strange because, how do you identify the difference of SIM cards? The device have 2 slots for 2 SIM cards right? So how do the two phone numbers differ?
  9. Tokolozi
    Well it's a carrier locked device. And AFAIK it has two sim slots, but since it's locked you would need to use two sims of the same carrier.... Which would be a bit silly.
  10. McJader
    McJader , Jan 26, 2021 :
    Tbh I find the entire notion of carrier-locked devices a bit silly
    Helder_DAlmeida, drl431 and Tokolozi like this.
  11. Tokolozi
    Well you're getting them on a discounted price usually. Which is handy. But yes, not anything I would do (and it's not possible here either)
    McJader, Helder_DAlmeida and drl431 like this.
  12. drl431
    That phone was originally a single sim device because it was carrier locked. When it was converted to a global model, the second sim option is added, but it still only has the single IMEI which is now duplicated.
    rhyd1am, Helder_DAlmeida and Tokolozi like this.
  13. Helder_DAlmeida
    McJader likes this.
  14. drl431
    Don't know how it will appear in that function, but in the status settings, it will appear 2 times with the same IMEI.
    the_o2, Tokolozi and Helder_DAlmeida like this.
  15. U1609690407679
    Cupcake Jan 27, 2021
    U1609690407679 , Jan 27, 2021 :
    Nope, I have offered from amazon.com. I cannot remember where, but i have read that it is possible to unplug from T-Mobile. After that operation imei have to change to a normal one. have someone heard about that?
