114
[Important] Re: Leaked Pie Build for OP3/3T
  1. rodger_rulez Gingerbread Apr 16, 2019
  2. ghostofcain Lollipop Apr 16, 2019
    ghostofcain, Apr 16, 2019 :
    The whole point of this thread, is that you flash a leaked build you are on your own, is that so hard to understand? Any issues with the build you've flashed have possibly already been fixed in subsequent builds.
    Bintang12 likes this.
  3. theshinybeast Lollipop Apr 16, 2019
    theshinybeast, Apr 16, 2019 :
    fastboot flash brain several new neurons
    Failed
    Error 708; brain cannot be found.
    otto2, Hydra Bob, Bintang12 and 4 others like this.
  4. virus streaming Gingerbread Apr 16, 2019
    virus streaming, Apr 16, 2019 :
    Y r u so objectionable, i m nt pointing any qst on op . Just want to know other users experience abt leaked pie build n i belive i can discuss with other users who have installed it.
  5. DarkSJ1998 Honeycomb Apr 16, 2019
    DarkSJ1998, Apr 16, 2019 :
    AFAIK, many of the people who flashed it used the Local Upgrade thingy and they were on stock recovery and they didn't face any errors during flashing. And, if the zip is modified in any way, the Stock Recovery would throw up an error as the zips need to be signed by OnePlus so that they can be flashed using Stock Recovery.
    A.SANKHYAN likes this.
  6. Vivek_Q Gingerbread Apr 16, 2019
    Vivek_Q, Apr 16, 2019 :
    No big deal It was not on daily driver it's was just test build in closed group someone leaked it. battery life was terrible.. Google CTS issues were there
  7. Bintang12 Honeycomb Apr 17, 2019
    Bintang12, Apr 17, 2019 :
    No
    Shooper likes this.
  8. A.SANKHYAN Cupcake Apr 17, 2019
    A.SANKHYAN, Apr 17, 2019 :
    tried the pie built from the XDA .. installed directly using stock recovery..
    Everything working fins but video calling.
    Video calling is showing microphone issue. I tried it via Duo & WhatsApp.
    And, also when you are on voice call notification bar won't come down unless you swipe all the way down.
  9. ghostofcain Lollipop Apr 17, 2019
    ghostofcain, Apr 17, 2019 :
    As the OP of this thread points out, this is not the place to discuss issues with the leaked build.
  10. virus streaming Gingerbread Apr 17, 2019
    virus streaming, Apr 17, 2019 :
    Sorry shaktiman
  11. ZVNexus Donut May 10, 2019
    ZVNexus, May 10, 2019 :
    Late reply, but I was amused by your comment. Qualcomm mode comes before the OS, recovery, or bootloader. Even if you completely wipe the NAND flash it WILL be intact. You can flash the partitions back using MSMDownloadTool, which is generally only provided to OEMs but often gets leaked (We have a tool for OxygenOS 5.0.8). Bootloop and infinite restarts, not being able to enter recovery are not "bricks". If you have no way of restoring these partitions, yes it is a brick. However we do.
    ghostofcain likes this.
  12. Bintang12 Honeycomb May 12, 2019
    Bintang12, May 12, 2019 :
    What's the form of "Qualcomm mode"?
  13. Hydra Bob Starting Point Expert May 12, 2019
    Hydra Bob, May 12, 2019 :
    Think of it as the Android equivalent of the Windows blue screen of death. When the system encounters a fatal error and is no longer able to continue running it enters a sort of hardware only mode where engineers and developers can retrieve a byte for byte dump of what was in the device's memory when the error occurred.
    otto2 likes this.
