Improvements to the Bluetooth audio settings
Thread Status:
Not open for further replies.
  1. VFR46HRC
    Donut Dec 7, 2019
    VFR46HRC , Dec 7, 2019 :
    Hello,
    I would appreciate if anyone knows how to tweak the audio settings for the Bluetooth from developers settings? I tried to change the settings to the best quality, but seems that they are locked.
    Thank you
    G_plusone likes this.
  2. G_plusone
    Nougat Dec 7, 2019
    G_plusone , Dec 7, 2019 :
    Can you go to the paired devices in Bluetooth and see if there is settings for Ldac for your Bluetooth headphones ?
  3. VFR46HRC
    Donut Dec 7, 2019
    Hello, sorry for the seladel reply. I checked what you mentioned me, I use the OnePlus bullets 2 wireless, it uses aptx hd 24/44,1kHz, but can't take it up to 24/96kHz which is supposed to be the aptx hd playing rate. Also as much as I tried,.I couldn't make any change to any setting within the following
  4. G_plusone
    Nougat Dec 8, 2019
    Best Answer
    G_plusone , Dec 8, 2019 :
    Sorry for bothering you with Ldac settings
    But OnePlus Bullets Wireless 2 only supports AptX HD audio which only supports 24bit/48khz
    according to their site
    https://www.aptx.com/aptx-hd
  5. VFR46HRC
    Donut Dec 9, 2019
  6. G_plusone
    Nougat Dec 9, 2019
    G_plusone , Dec 9, 2019 :
    No problem.
    You too have a good day
  7. Gaston NP
    Moderator Moderator Dec 9, 2019
