19
Sound Incoming call issues.
  1. ultrashock2112
    Froyo May 28, 2020
    ultrashock2112 , May 28, 2020 :
    Hi all,
    I've been having a recurring, occasional, issue when I receive calls and when I answer the call I can't hear the person on the other end, and they can't hear me. If I look at the screen it appears that the call is connected and the call timer is running, but no audio.
    It's not consistent, but rebooting seems to resolve it. I also tried clearing the phone app data but the issue has reoccurred since.
    I occasionally use a bluetooth headset for calls, and I wonder if it's somehow related. I know that the headset is NOT connected when the issue occurs because 1) the headset is powered off, and 2) the bluetooth icon in the status bar doesn't show the connected "dots" on it. I've also tried switching to the speaker (from the phone app) when this issue occurs but the speaker produces no sound either.
    This behaviour doesn't seem like a hardware issue to me and I'm surprised if I'm the only one having this problem...
    Thanks
  2. nicolamoto
    Cupcake May 29, 2020
    nicolamoto , May 29, 2020 :
    Bonjour j'ai le même problème de temps en temps. Je suis chauffeur livreur et le téléphone est relié au bluethoo du camion .en redémarrant le téléphone le problème est résolu pour la journée
    Clt
  3. Ozgur_Tarakci
    Donut Jun 1, 2020
    sjh69stem likes this.
  4. IgelON3
    Cupcake Jun 3, 2020
    M1539276572626 and sjh69stem like this.
  5. ultrashock2112
    Froyo Jun 3, 2020
    ultrashock2112 , Jun 3, 2020 :
    Glad to see that I'm not the only one having this issue. Could you guys upvote this thread? I think that it's probably the only way that someone from OnePlus might pay attention to it...
    sjh69stem and MrMousey like this.
  6. F_Henrik_Madsen_wfQs
    Honeycomb Jun 3, 2020
    F_Henrik_Madsen_wfQs , Jun 3, 2020 :
    Having a nearly identical issue, it just happens mid call.
    Next time it happens, try to hit MUTE and then UNMUTE and see if it resolves the problem.
    This method seems to work for me.
  7. ultrashock2112
    Froyo Jun 3, 2020
    Thanks I'll try that next time. Still hope it gets fixed...
  8. ultrashock2112
    Froyo Jun 4, 2020
    ultrashock2112 , Jun 4, 2020 :
    Issue happened last night and I tried mute/unmute - no luck. Had to disconnect call and call the person back.
    MrMousey likes this.
  9. MrMousey
    Froyo Jun 6, 2020
    MrMousey , Jun 6, 2020 :
    I'm having the exact same issue on my brand new OnePlus 8 Pro! I thought it was just me having this issue. Glad I checked the forums first. Just like you, the issue happens occasionally. No telling when it will happen. It's luck of the draw. It happened to me 3 times yesterday and on my first phone call this morning.
    A couple things I have noticed so far when the issue occurs are:
    1. The call is in HD voice (Has the HD symbol beside call timer)
    2. Switching from bluetooth (whether I'm connected to my car or a headset) to phone or speaker does not resolve the issue. silence on all 3 audio sources.
    3. Doesn't matter what network the caller is calling from. I've had calls from people on 2 completely different carriers (Rogers and Koodo/Telus) and it happened. One of which I am on (Koodo).
    I know someone here mentioned they were having the issue with their 6T. I have the 6T, 7Pro and now the 8Pro and have mainly experienced the issue with the 8Pro so far. I've only had the issue once with my 7Pro and that was some time last year. Nothing again since then. I'm currently on Oxygen OS 10.5.6.IN11AA on my 8Pro.
    Like you've mentioned, hopefully this thread catches the attention of OnePlus and they address the issue right away. It's really annoying saying hello, hello, then having to hang up and call the person back in hopes the call will work properly. And also fix the dual SIM issue for the 8 series phones already! I know there is another thread for that so I will take my complaints on that issue there. But seriously OnePlus, please look into this incoming calls issue. It's clearly affecting more than just one model.
    Guys, try to put as much detail as possible in your posts about the issue (eg. model, OS version, Carrier, etc..). hopefully that'll also help this thread get into OnePlus Supports view.
    getefix, philhh27 and ultrashock2112 like this.
  10. ultrashock2112
    Froyo Jun 8, 2020
    ultrashock2112 , Jun 8, 2020 :
    Thanks for the detailed description - definitely sounds like the same issue. I'm on Telus as well, although I guess I'd be surprised if that's nothing more than coincidence. I'm not sure how to get Oneplus' attention with this.
    getefix, philhh27 and MrMousey like this.
  11. MrMousey
    Froyo Jun 8, 2020
    MrMousey , via OnePlus 8 Pro , Jun 8, 2020 :
    ultrashock2112
    Thanks for the detailed description - definitely sounds like the same issue. I'm on Telus as well, although I guess I'd be surprised if that's nothing more than coincidence. I'm not sure how to get Oneplus' attention with this.​
    that is quite the confidence. as for getting OnePlus involved, your guess is as good as mine. hopefully someone gets a hold of this soon. I literally got the phone last week and had this issue the 2nd day in. it's too early for me to have to do a hard reset on it and I can't return the phone because my 30 days had long passed (long story) lol. have you completed a hard reset on yours as of yet?
  12. ultrashock2112
    Froyo Jun 8, 2020
    I haven't done a factory reset but I have wiped the phone app data. Like you, I've been having this issue since day one so I'm skeptical that a factory reset would have any positive effect. I did see some exceptions in the logcat (I believe from the telecom service) which I'll try to capture next time it happens.
  13. MrMousey
    Froyo Jun 8, 2020
    if the dual SIM on this phone was working, I'd be able to test out my 2nd SIM from at&t to see if the same thing happens with that. but, no such luck on that. hopefully you're able to capture some logs to get a better insight as to what the problem may be. also other people having this issue will find this thread and post their experiences to get more traction from OnePlus in trying to resolve this issue
  14. IgelON3
    Cupcake Jun 10, 2020
    IgelON3 , Jun 10, 2020 :
    Now with 10.5.9 still the same
    I have just one sim in port 1. VoLTE and WLAN Call is deactivated. Provider is Telekom (Germany)
  15. MrMousey
    Froyo Jun 25, 2020
    MrMousey , Jun 25, 2020 :
    So after an update to 10.5.10, I'm still having the problem. It seemed like it went away at first but then a clue days later...... here we go again. This time I had the problem not only when receiving case while my Bluetooth headset was connected but, also when no Bluetooth headset was connected. So just using the actual handset to make and answer calls. Still putting it on speakerphone doesn't help.
    I've also discovered the issue is present when I make calls too. This part is new as it didn't happen when I last posted before the update. In addition to that, the issue doesn't only happen when it is in HD voice. It also happens when it's just a regular call as well.
    This is very disappointing that OnePlus hasn't even made a mention or attempt at trying to resolve the issue. I'm also noticing that my service is not that good with this phone. In the same places where my 7 Pro had full service with the same SIM, my 8 Pro is telling me I have 1-3 bars of service. Looks like I'm gonna have to switch back to my 7 Pro because this sound issue is killing me. 50% of my calls today experienced the problem. This is very problematic considering I use my phone to actually communicate with people by voice and I also use it for work. Doesn't look very professional when I have a client call me and I can't hear them so I have to hang-up and call them back.
    N1595000388190 likes this.
  16. Andyshaw1
    Cupcake Jul 1, 2020
  17. ultrashock2112
    Froyo Jul 8, 2020
    N1595000388190 and MrMousey like this.
  18. MrMousey
    Froyo Jul 11, 2020
    MrMousey , Jul 11, 2020 :
    I wish I did. I actually called them about 2 weeks ago and brought the reps attention to this thread. Sad to see it didn't do a damn thing cuz I haven't seen anyone from OnePlus comment on here.
    When I called them, they first tried to tell me the issue was with my SIM. Then they tried to say that the phone is not capable of 4G connectivity so I needed to go an update my SIM to a 5G SIM. To which I said, it made no damn sense and I wouldn't be doing that! Mainly cuz there's no 5G in my area so why do I care about 5G and the phone if the phone didn't support 4G connectivity, what is supposed to happen when someone gets out of 5G reception? They then gave me some other steps to perform which I've shared below. I've tried the network reset and running the phone in Safe Mode (FYI, no access to 3rd party apps when using safe mode) and I was still having the issue.
    please perform a network reset and after that perform the safe mode operation by following the steps below :
    Safe mode :
    1) Press Power button for 2 seconds until you get the list of options such as power off, restart and emergency
    2) Press and hold on the Power off option for 2 seconds
    3) Select OK to reboot to safe mode
    Here are the steps to capture the log for the issue:
    1. Input *#800# from dialing interface, enter ""OnePlus log kit"", delete history log
    2. Click ""Network Tcpdump Log and ""Move log path to built-in SD card"" and then Click ""save log"", do not reboot device.
    3. Click ""get QXDM Log"", choose ""modem-common"", and then click ""open device log""
    4. Reproduce the issue and take a screenshot to record the time, then stay for a few minutes (better above five minutes)
    5. Enter ""get QXDM log"" and choose ""close device log"", and then click ""save log"" again to stop(uncheck) it
    6. Enter File manager >Internal storage > oem_log >diag_logs to check if the sub folder date was the latest.
    7. Finally, send us the whole oem_log folder (file manager-storage) along with the screenshots"
    For the Network Reset, go to: Settings > System > Reset options > Reset Wi-Fi, mobile & Bluetooth > RESET SETTINGS.
    Give the steps a shot and see if it works for you. I've tried and it hasn't been successful for me but hopefully it proves to work for someone else.
    P.S.
    Anyone else having issues posting things from the Community app? Every time I try to post or reply via the app it never goes through.
  19. rajeevranjanonline
    Cupcake Jul 15, 2020
  20. rajeevranjanonline
    Cupcake Jul 16, 2020
    rajeevranjanonline , Jul 16, 2020 :
    I wrote to guys at OnePlus and here is what they responded. It's been a few hours and all calls have worked so far 🤞
    We request you to perform the below steps and check if the issue resolves:
    Go to settings > Search Reset > Reset option > reset Wifi, mobile & Bluetooth.
    Thanks
