Incoming call - phone doesn't wake up via OnePlus 3T
  1. pankaj1675
    Cupcake Aug 20, 2020
  2. yamin_bhoira
    Cupcake Aug 21, 2020
    yamin_bhoira , via OnePlus 3 , Aug 21, 2020 :
    Yes, Facing the same issue since 4-5 months, the whole ring goes on until it ends but the screen does not wake and show us the options to accept or recject. It is so annoying. Even if we try to wake the screen with power button or anything it does not happen. Please if someone with oneplus 3 is facing the same issue and knows how to resolve the same, help us.
  3. gazz1701
    Jelly Bean Aug 21, 2020
    gazz1701 , via OnePlus 3T Midnight Black , Aug 21, 2020 :
    What version of OxygenOS are you running? Have you tried a factory reset? Are you running default phone app or installed a different app?
  4. yamin_bhoira
    Cupcake Sep 19, 2020
    yamin_bhoira , via OnePlus 3 , Sep 19, 2020 :
    Oxygen Version 9.0.6
    No i have not done a factory reset ever since
    And i am using the default phone app and no third party apps are as default or no such permissions granted for calls. Thank you for addressing.
  5. gazz1701
    Jelly Bean Sep 20, 2020
    gazz1701 , via OnePlus 3T Midnight Black , Sep 20, 2020 :
    You should try a factory reset, but this will wipe all data and setup, so ensure you have all your data backed up...
  6. MMGnanavel
    Cupcake Sep 20, 2020
    MMGnanavel , Sep 20, 2020 :
    I am also facing same problem last one week kindly suggest , how to solve this issuse
