Incoming calls Are Not Visible.
  1. Shubham_4278
    Cupcake May 24, 2017
    Shubham_4278 , May 24, 2017 :
    Incoming calls Are Not Visible, it only show the notification when my cellphone is ringing. Incoming calls are not visible in full screen.
  2. dsmonteiro
    Community Consultant Community Expert May 24, 2017
    dsmonteiro , May 24, 2017 :
    Which OS version are you on? Did you install any additional dialers?
  3. mr_priyanshu
    Jelly Bean May 24, 2017
    mr_priyanshu , May 24, 2017 :
    When the screen is ON, it appears as notification.
    When the screen is OFF/locked, it appears on the whole screen
  4. saikiran4ever
  5. G_Denny_Mathew_Rpgr
  6. inffy
    Nordics POC Assistant Head Moderator May 24, 2017
    inffy , May 24, 2017 :
    If your phones alert slider is in the middle position it won't show notification, it will only light up the statusbar
    viraaj11 likes this.
  7. G_amrita_shivani_fjvs
    Cupcake Jul 2, 2017
  8. L1569238115036
    Cupcake Sep 23, 2019
    L1569238115036 , Sep 23, 2019 :
    Incoming calls are not visible....able to hear only sound....after 20 or 30 seconds only display will appear.... am using one plus 3 and the android version was 9 and the oxygen version was 9.0.5...kindly give me the solution as soon as possible
  9. L1569238115036
    Cupcake Oct 9, 2019
    L1569238115036 , Oct 9, 2019 :
    ok version 9.05
    Not installed any dialer
  10. L1569238115036
    Cupcake Oct 9, 2019
    please help me to solve the problem...
  11. a_agarwal
    Ice Cream Sandwich Oct 16, 2019 at 4:42 AM
    a_agarwal , Oct 16, 2019 at 4:42 AM :
    Same problem. I have to unlock the phone and then also it takes a few seconds to display who is calling. Until then it is a non responsive screen.
    (OP3T, Pie latest official update, not rooted)
