incoming calls are unavailable via OnePlus 7
  1. aasis.malla
    Cupcake Jan 29, 2020
    aasis.malla , via OnePlus 7 , Jan 29, 2020 :
    people are trying to call me .. but it says unavailable at the moment.. then they reach out to me on social media,this is the only way i know about this problem... this problem only gets solved after i aeroplane mode on then off...
  2. RahulGupta995
    Gingerbread Jan 29, 2020
    RahulGupta995 , via OnePlus 7T , Jan 29, 2020 :
    This is a network or service provider issue it's not the issue of the device try contacting your service providers for this issue and report them.
    If you want to confirm then put another sim and see if the same problem exists with the same sim.
  3. Q1579760293333
    Q1579760293333 , Jan 29, 2020 :
    am experiencing the same issue.sim works fine with other mobile phones.reset device,still the same
  4. P1567582282474
    Cupcake Jan 30, 2020
    P1567582282474 , via OnePlus 7 , Jan 30, 2020 :
    Hi All,
    While I am on the phone and new calls come through, they go straight to voicemail. I don't get any incoming call alert etc etc.
    I have gone through the settings but can't find the answer anywhere! thanks for you help!
  5. dilushan 787
    Cupcake Feb 20, 2020 at 5:57 PM
