Incoming calls doesn't appear/notify during on going calls on Oneplus 6
  1. Sparshgarg174
    Donut Mar 16, 2019
    Sparshgarg174 , Mar 16, 2019 :
    Hi, I have an unusual problem on my Oneplus 6. If i am on call with someone and a third person is ringing me during that time, my phone doesn't show any kind of notification(screen pop-up, vibration, ringing). Its doesn't even get registered in call logs as missed calls!
    There is no way i get to know if someone had called me while i was on call.
    I didn't even know my phone had this problem until recently few of my colleagues pointed out that i am not calling them back.
    >When i am on call i do not get notified if a third person is calling.
    >post the call gets completed there no call log registration for that third person as missed call or something else.
    >The third person gets proper info that the line is busy as i am on other call.
    >I tried turning some settings on and off in default calling app but nothing seemed to work.
    >Below are the screenshots to my current dialler settings.
    P.S : One other op6 user known to me seems to have the same issue so it seems like a common bug.
  2. SayanMandal
    Gingerbread Mar 16, 2019
    Sparshgarg174 likes this.
  3. Deactivated User
    Mar 16, 2019
  4. Sparshgarg174
    Donut Mar 16, 2019
    Hi, i already tried different combination of settings there.. No luck with the one's i have tried.. maybe this isn't the solution or i haven't hit the correct combination yet.
  5. B1552743901147
    Cupcake Mar 16, 2019
  6. Deactivated User
    Mar 16, 2019
  7. Sparshgarg174
    Donut Mar 16, 2019
    The carrier perspective might be the case.. i'll try using the some other carrier as well and let you know. And can you pls share the screenshot of setting thats working for you? I replicate the same and check.
  8. Birendra U
    Cupcake Mar 17, 2019
  9. B1552743901147
    Cupcake Mar 18, 2019
  10. Carman00
    Gingerbread Mar 18, 2019
  11. Sparshgarg174
    Donut Mar 19, 2019
    Sparshgarg174 , Mar 19, 2019 :
    Yes the call waiting option was the solution and it worked!!
    Thanks a lot bud.
    Jaychoudhary21 likes this.
  12. Carman00
    Gingerbread Mar 19, 2019
    Carman00 , Mar 19, 2019 :
    NP
  13. Q1541658370091
    Cupcake Jan 2, 2020
