Incorrect temperature notification
  1. M1560270869156
    Donut Jul 18, 2019
    M1560270869156 , Jul 18, 2019 :
    I have purchased one plus 7 a month ago.i used to receive temperature notifications on screen i.e mostly showing above 89degree celicus.But in actually it is wrong temperature showing.Then I clicked on that notification ,after opening the application it is showing current temperature .Only in notification it is showing wrong.i checked also in settings in which degree celcius is selected.
    screen shot attached of both conditions ,1st of notification and 2nd after opening of notification,the main temperature app screen.i think it's a bug . kindly issue patch for it
  2. Gdsingh94
    Honeycomb Jul 19, 2019
  3. Arjun Choudhry
    Arjun Choudhry , Jul 19, 2019 :
    Kindly don't create redundant threads. It clutters up the forums. And this issue has got nothing to do with OnePlus. It's entirely Google's fault. Please do your research, search for similar threads, and only if no similar thread is found, then make a new thread.
  4. M1560270869156
    Donut Jul 19, 2019
  5. M1560270869156
    Donut Jul 19, 2019
  6. ngydat
    KitKat Jul 19, 2019
    ngydat , Jul 19, 2019 :
    @M1560270869156 Clearly the temperature displayed in the notifications are in degrees Fahrenheit. So, go into the settings of the One Plus Weather app and set the temperature to degrees Celsius.
    Also, next time, when you just want to tell us that your issue happens with a particular app, there's no need to post a screenshot of the app in the Play Store. I think we're all educated enough to be able to read the name of the app. So, in this message
    The screenshot was unnecessary
  7. M1560270869156
    Donut Jul 19, 2019
    M1560270869156 , Jul 19, 2019 :
    I have already done the same.. already in my settings it has been set as Degree Celsius .But still in notifications it is showing other, and that is not in Fahrenheit also as per conversion calculation.
  8. M1560270869156
    Donut Jul 19, 2019
    Therefore i shared this here.In first 2 attached screen shots i tried to clear the same as it is showing on notification 92degree but after opening app it's showing 28 in degree Celsius.
    if 92 is in farenhite then it is wrong.because while calculating conversion, 28 degree Celsius should be equal to 82.4 degree Fahrenheit.
    so it is clear that in notifications it is neither showing farenhite nor Celsius. It is other garbage value.
  9. M1560270869156
    Donut Jul 19, 2019
  10. gizwiz
    Cupcake Jul 19, 2019
    gizwiz , Jul 19, 2019 :
    I think the issue is genuine and not redundant as well. one plus need to look even if it's Google's fault.
    G_Russ_Harding_ZQFi likes this.
  11. Matt 80
    Lollipop Jul 19, 2019
    Matt 80 , Jul 19, 2019 :
    No they don't.
    Oneplus look into oneplus issues.
    Google issues are looked into by.....GOOGLE.
  12. M1560270869156
    Donut Jul 19, 2019
  13. M1560270869156
    Donut Jul 19, 2019
    we have got OnePlus with some inbuilt applications like Gmail,Google,maps, YouTube,drive etc ..
    Google installed it on phone with collaboration of one plus. Then if any problem occurs from Google side on OnePlus handset then it's also a responsibility on OnePlus to take up matter with Google . Because it's may affect it's credibility.
  14. gizwiz
    Google is not an application that it has to fix itself for one plus phones, last time I checked it was mobile operating system and one plus is using Google's customized oxygen os.
  15. M1560270869156
    Donut Jul 19, 2019
  16. Matt 80
  17. igen
    Gingerbread Jul 21, 2019
    igen , Jul 21, 2019 :
    The dude is facing issue with the Oneplus Weather app so he posted in the forums. Anyway OP clear cache and data of Oneplus Weather then open it and set temp to celsius and check if it happens again.
