Indicator light Issue via OnePlus 7 Pro
  1. P1581960995493
    Cupcake May 30, 2020
    P1581960995493 , via OnePlus 7 Pro , May 30, 2020 :
    After using 2 days... noticed that there is a white LED that keep flickering even after the earphones are connected to the phone. It flickers quickly twice, every 4-5 seconds and gets quite distracting, especially in dark. is there any solution for this?
  2. AbhilashSaikia
    The Lab - OnePlus 8 Pro Reviewer May 31, 2020
    AbhilashSaikia , May 31, 2020 :
    If you're using a Bullets Wireless earphone, it is normal. According to OnePlus Support, "It is to indicate that it has been connected to your device."
    Also, you're requesting for help in the wrong section. Please stick to the device-specific thread.
    Thanks!
    P1581960995493 likes this.
