129
Inside OnePlus: The evolution of OnePlus fast charging
  1. Kaushikvaland
    Froyo Sep 25, 2020
  2. Andy lone
    Honeycomb Sep 25, 2020
    #62
  3. Nasir_Alam
    Froyo Sep 25, 2020
  4. Plenkske
    Assistant Head Moderator Assistant Head Moderator Sep 25, 2020
    Plenkske , Sep 25, 2020 :
    The charging tech OnePlus uses is still unmatched and awesome :)
    Thanks for all the information !
    #64
  5. Tuomas L.
    Head of Strategy, OnePlus Europe Staff Member Sep 25, 2020
    Tuomas L. , Sep 25, 2020 :
    Hey Mojoyoyo77, usually electricity is paid by the amount of power consumed, which is depending on how big of a battery you are charging. So the time used does not matter.
    #65
    jlasensiofi and Plenkske like this.
  6. mojoyoyo77
    mojoyoyo77 , Sep 25, 2020 :
    Maybe I didn't explain myself well, let's put ourselves in a hypothetical case:
    With a 4000 mAh battery, a battery compatible with all systems, we use different charging systems Dash, Warp, ..., the higher the power, we use less time, but losses always occur during charging, for example due to heat generated, the electricity consumption is the same? Is it greater? Or the new systems are also improving energy efficiency and is it less?
    #66
  7. #67
  8. Chaitanya_15920
    Eclair Sep 25, 2020
    #68
  9. harshh36
    Froyo Sep 25, 2020
    #69
  10. KaustubhLXIX
    Froyo Sep 25, 2020
    KaustubhLXIX , via OnePlus Nord , Sep 25, 2020 :
    It's not InNOVatIvE. Other manufacturers have done this WAY before you did,you're just catching up.
    Why don't you guys work on fixing Nord's tint, reset issues,5T's delayed updates,8 Pro's battery drain.....instead of marketing?
    Your customers would be MUCH happier.
    #70
  11. [email protected]
    Gingerbread Sep 25, 2020
    #71
  12. Plenkske
    I understand your point. Lets put some numbers to it, to make it more clear.
    These numbers are fictional.
    Warp Charge 30
    Battery gets charged in 2 hours. Average power usage in that time is 30 Watt. This is a power usage of 30 Wh or 0,03 kWh. After 2 hours you have used 60 Wh or 0,06 kWh.
    Warp Charge 65
    Battery gets charged in 1 hour. Average power usage in that time is 65 Watt. Power usage is 65 Wh or 0,065 kWh.
    So in this fictional example the power usage is slightly higher with the new warp charge.
    I think what @mojoyoyo77 wants to see is the REAL numbers. Is the total power usage almost the same ? Then its fine in my opinion. If its much higher then the question is if you would really want it. If its much lower then thats awesome :)
    #72
    jlasensiofi likes this.
  13. Young_Blood
    KitKat Sep 25, 2020
    #73
  14. Belieber135
    Belieber135 , via OnePlus Nord Gray Onyx , Sep 25, 2020 :
    OnePlus Warp Charge is the Best and the team won't stop making more and more focus on Warp Chargers. Every new release comes with a new Kind of warp charging. Excellent post OnePlus Team [e]1f44f[/e]🏻[e]1f44f[/e]🏻[e]1f44f[/e]🏻
    #74
  15. KaustubhLXIX
    Froyo Sep 25, 2020
    #75
  16. Dhruv195
    Eclair Sep 25, 2020
    #76
  17. zayn_ys
    Ice Cream Sandwich Sep 25, 2020
    #77
  18. piyush17j
    Froyo Sep 25, 2020
    piyush17j , via OnePlus 7T , Sep 25, 2020 :
    I always find OnePlus charging as much better for the time period when it's launched currently I am using 30T but now see it launched a new with 8T seriously OnePlus have one of the greatest advantage in charging and unlike it's competitors it provide in box charging accesories.
    #78
  19. cdnfarmer
    Moderator, Photography Expert Moderator Sep 25, 2020
    cdnfarmer , Sep 25, 2020 :
    Good job to all those who worked endlessly and hard on making the improvements.
    Very interesting how the progress was made over time and now, it was moved from changes to the cable and brick to include having two batteries.
    #79
  20. Shadow_Z2201
    Cupcake Sep 25, 2020
    #80
