2
Instagram App Wifi problem
  1. Harris03
    Donut Jan 25, 2018
    Harris03 , Jan 25, 2018 :
    hello, the instagram app doesnt load when i am using the wifi, I mean it doesnt refreshes to the latest posts. It is only works when I am using the data. this problem exists a lot of months it is now new. I always update the app to the latest release but nothing happens. I also have deleted and re istalling the app a lot of times. what about you?
    it is a mobile problem or the instagram have to fix it?
    thank you.
    T1546876657772 and jferraz like this.
  2. Harris03
    Donut Jan 26, 2018
    Harris03 , Jan 26, 2018 :
    i found the solution :
    Accidently I restricted WIFI for Instagram app. So when I enabled it again everything works perfect!!
    G_Pulkit_Singh_xTUJ likes this.
  3. ptn
    Eclair Feb 15, 2018
    ptn , Feb 15, 2018 :
    I have the same problem, how do I restrict wifi for Instagram and re-enable it????
  4. Harris03
    Donut Feb 15, 2018
    Harris03 , Feb 15, 2018 :
    go to settings -> apps -> instagram -> data usage and there is an option to enable or disable wifi
  5. ptn
    Eclair Feb 15, 2018
    just found a
    in APP USAGE DATA that wifi was disabled, this is incredibly ridiculous... but there you are, thanks for this at least I found the problem
  6. ptn
    Eclair Feb 15, 2018
    In Oneplus 3 just go to settings, Apps, Application List, Instagram, Data Usage, Unclick wifi disabled...
  7. OlivrexD
    Donut Jun 21, 2019
    T1546876657772 likes this.
  8. S_Kashyap
    Cupcake Oct 15, 2021
    S_Kashyap , Oct 15, 2021 :
    I tried to disable and enable the wifi in data usage and also tried resetting wifi settings from networks .Still both of the steps did not work.
    Instagram is working in mobile data but not in wifi.
  9. buntycubal
    User of the Year 2017 Oct 24, 2021
