Instagram Notification Issue
  1. Rushikesh gurav
    Donut May 21, 2019
    Rushikesh gurav , May 21, 2019 :
    Last couple of week's the Instagram notification was not displaying. I tried each an every possible action but it's still not working. Even I 5+ time's reinstalled the Instagram but still facing the same problem. Also sharing the setting of the application and notification details too.
    psketch likes this.
  2. Artemus.
    Nougat May 21, 2019
    Artemus. , May 21, 2019 :
    Eagerly awaiting that girl's DM response? You sly dog, you.
    Caomhin likes this.
  3. Rushikesh gurav
    Donut May 21, 2019
    Thanks for your valuable reply.
  4. DVNK09
    Gingerbread May 21, 2019
    DVNK09 , May 21, 2019 :
    So a few suggestions here that may work. you can go into battery optimizer and put don't optimize for Instagram, you can make sure that your deep clear isn't on for recent app management. also go into Instagram itself and check if there is a setting in Instagram that has any notifications turned off, if you do not find anything from there let me know.
    Rushikesh gurav likes this.
  5. Sharry7
    Ice Cream Sandwich May 22, 2019
  6. Rushikesh gurav
    Donut May 22, 2019
    Rushikesh gurav , May 22, 2019 :
    Yea I tried as your suggestions, but still it not working. By the way Thanks for your valuable suggestions.
  7. Rushikesh gurav
    Donut May 22, 2019
  8. Raresch
    Raresch , May 22, 2019 :
    go to the settings page that you posted the first time. if you press the name of the notification, you will have more option. make sure all of them are set on: Make sound and pop up. some might be set on: do nothing
    Rushikesh gurav and Artemus. like this.
  9. Rushikesh gurav
    Donut May 22, 2019
    Tried... Still not working. Thanks for your Valuable Response.
    Raresch likes this.
  10. E1548154795430
    Cupcake Oct 1, 2019
    E1548154795430 , Oct 1, 2019 :
    Hello Rushikesh how are you? Did your problem got solved of not getting Instagram notifications. As I am facing the same issue.
  11. Rushikesh gurav
    Donut Oct 1, 2019
    Rushikesh gurav , Oct 1, 2019 :
    Hey Hi. No its still not working.
  12. E1548154795430
    Cupcake Oct 1, 2019
    which one plus you are using? one plus 6?
  13. Rushikesh gurav
    Donut Oct 1, 2019
  14. E1548154795430
    Cupcake Oct 1, 2019
    same here..I guess there's problem in one plus 6 only..tried every possible way but all futile.
  15. Rushikesh gurav
    Donut Oct 1, 2019
    Chill bro.. Its not problem with our 1+6... It's just some advance settings by 1+ and Instagram can't handle it so that's why the problem occurred.. That's it..
    K1572031338018 likes this.
  16. TusharRai09
    Cupcake May 6, 2020
  17. DVNK09
    Gingerbread May 6, 2020
    DVNK09 , via OnePlus 7 Pro , May 6, 2020 :
    What software version are you running?n
  18. Daniel_Klein
    Cupcake May 18, 2020
  19. Artemus.
    Nougat May 19, 2020
    Artemus. , May 19, 2020 :
    Wrong section.
    Caomhin likes this.
  20. V1590710716042
    Cupcake May 29, 2020
    V1590710716042 , May 29, 2020 :
    bro same situation for me right now in my oneplus 7 pro. did u get any solution for the problem.help me
