instagram stories are not loading
  1. G_supriya_rasal_jTgy
    Cupcake Aug 4, 2017
    G_supriya_rasal_jTgy , Aug 4, 2017 :
    instagram stories are not loading ... please help me out with the issue .. i tried uninstalling n reinstalling instagram alsoo bt its not working out
  2. Prashant_Pillai
    Froyo Aug 4, 2017
    Prashant_Pillai , Aug 4, 2017 :
    Did you check your network connection? Do the stories load initially or is the app crashing when you try and open a story?
  3. G_supriya_rasal_jTgy
    Cupcake Aug 4, 2017
  4. varma246
    Lollipop Aug 4, 2017
    varma246 , Aug 4, 2017 :
    Once Force stop Instagram app in settings and see.
  5. G_supriya_rasal_jTgy
    Cupcake Aug 4, 2017
  6. puneetkm17
    Eclair Aug 4, 2017
  7. varma246
    Go to settings-apps-instagram- storage-clear cache app,if didn't work Clear Data of it and reboot your device.
    Make sure App is up to date.
  8. G_supriya_rasal_jTgy
    Cupcake Aug 5, 2017
    G_supriya_rasal_jTgy , Aug 5, 2017 :
    i did dt tooo bt still its not working .... its really getting annoying now...i rebooted the device soo many times i followed all d steps also whetrvr u said bt still its nt working ... i checked my network connection too it working well ...
  9. varma246
    Lollipop Aug 5, 2017
    varma246 , Aug 5, 2017 :
    Ok!...one final thing left uninstall and install Instagram app as you are saying you network connection is well. it's definitely issue of Instagram app send a feed back to the developers of it.
  10. rajesh.rcr38
    Cupcake Sep 28, 2017
    rajesh.rcr38 , Sep 28, 2017 :
    Go to settings -> Date and Time -> check the auto date and time(Dont set date and time manually change it to auto) and reboot your phone it works !!!
  11. Y1520995501338
    Cupcake Mar 14, 2018
    Y1520995501338 , Mar 14, 2018 :
    THANK YOU SO MUCH! I HAD BEEN STRUGGLING FOR WEEKS AND NOW IT'S FIXED. I FOUND OUT IT WAS MY FAULT FOR CHANGING THE TIME ONE DAY AHEAD FOR A STUPID GAME I HAD.
  12. P1562180597607
    Cupcake Jul 3, 2019
    P1562180597607 , Jul 3, 2019 :
    Where is that at? I don’t have that
  13. Deactivated User
    Jan 29, 2020
  14. itsmdkaif
    Cupcake Jan 30, 2020
    itsmdkaif , Jan 30, 2020 :
    Yes i reinstalled app, cleared cache and data , tried login into another phone..
  15. itsmdkaif
    Feed isn't refreshing showing a one post all day on top...and main issue I'm not able to create highlights because my achieved stories are not loading .. showing just black..
  16. Deactivated User
    Jan 30, 2020
  17. itsmdkaif
    But why it is happening only to me ...is there any ..can you give me Instagram helpline mail
  18. Matt 80
    Lollipop Jan 30, 2020
    Matt 80 , via OnePlus Community App , Jan 30, 2020 :
    If you don't want to get spammed, I suggest you remove your email address from this Internet forum.
    I'm sure you can find that with a simple Google search
  19. itsmdkaif
    I've tried...but nobody is facing this issue that's why no solution is available online ..if you know tell me or give me link
  20. Matt 80
    I've already told you that the Instagram helpline can be found very easily using Google.....I'm sure you know how to use google search.
